Question about GPX MW3837 MP3 Player
I can't sync my music list to gpx mp3 player
It either states:
When it MTP -- It is not possible to change sync settings at this time. Try again later.
    Problem Solver:
  • 15 Answers
On the mp3 player, switch between the Usb and Mtp mode (The M button) on the side of the player.
Posted on Apr 19, 2010
How to put music
To copy music files onto your device:
  1. Connect your MP3 player to your computer using your USB cable. Switch your MP3 player to the MTP mode by pressing the power button located on the top of your player. When the USB symbol disappears your MP3 player is in the MTP mode.
  2. Opening your GPX audio player folder by clicking 'Start' on your computer.
  3. Click on 'Start'.
  4. Double Click on the 'GPX MTP Device' icon.
  5. Double Click on 'Removable Storage'. Minimize your 'Removable Storage' window.
  6. Open your 'My Music' folder by again clicking on 'Start' and then click on your 'My Music' folder. Choose an album or individual songs from this folder. With both your 'My Music' and 'GPX MTP Device Removable Storage' folder open. Drag an album or individual song from your 'My Music' folder into your 'Removable Storage' folder.
Here is a link to the whole user's manual:
http://www.gpx.com/owners_manuals/ML648B-IB.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | GPX ML648B MP3 Player
How do i add and take music off
take the usb cable that came with your player, and plug into your computer and your player, After you plug in the player set it to MTP instead of USB, by using the top right button. Windows will ask what you want to do, select sync with windows media player. once wmp is open, go to your sync tab abd drag and drop music into the mp3 player pane, when you have all the music you want or you are out of space, click the "start sync" button at the lower right. Helpful hint "make sure all files are the same type, mp3,acc,wma.... you will fit alot more songs on the player."
Then if you want to take off only a few songs, just plug in the player and start Windows Media, select your mp3 player from the list on the left, the just left click to hi-light the song and press delete on the keyboard, click yes if asked "are you sure you want to delete"? Or you can format if you want to start fresh.
Mar 05, 2010 | GPX MW-3847 MP3 Player
Device will not sync. i only have 1% memory on the gpx mtp. it says no file, when there is sonngs on the player.
it happens if the file is got corrupted or not getting read properly.reformat the mp3 player drive then check again by reloading the files again.then sync and check out.
Aug 30, 2009 | GPX MW-3847 MP3 Player
How do I download music on my mp3 player? I bought the mp3 player(gpxml638b) and it did not have any soft ware. I have the wire to plug from mp3 to computer, but how do I start downloading music?
Sir,
1. Turn on the MP3 Player by holding the PLAY/PAUSE button.
2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer.
3. When connected the LCD Display will either say “USB” or “MTP”.
4. Press the “M” (mode) button to switch between “USB” and “MTP” mode.
“MTP” mode will only work, when your player is connected to Microsoft
® Windows® XP and Windows® Media Player 10.
The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional.
1. Start Windows Media Player 9 and connect the MP3 Player to your computer.
2. Click “Copy to CD or Device”.
3. In the drop-down list, on the “Items to Copy” pane, click the play list, category, or other item that you want to copy.
4. Clear the check boxes next to any files you do not want to copy.
5. In the drop-down list, on the “Items to Copy” pane, click the device that you want to copy files to.
6. Click the ‘Copy’ button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
1. Start Windows Media Player 10 and connect the unit to your computer. On your player’s display it should say ‘MTP’. If not, then while the unit is connected press the ‘M’ (mode) button to change from ‘USB’ to ‘MTP’ mode.
2. If you have not set up synchronization between your computer
and this device, the Device Setup Wizard starts. In the Device Setup Wizard, select Manual.
3. Click Finish.
4. Select Library option. On the right pane select Sync List.
5. From the left pane you can select the Play list or Library and you will see the content songs in the center pane.
6. Select the songs from the center pane, drag and add them to the Sync List.
7. Click the ‘Start Sync’ button in the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Thanks
Good Luck
Aug 17, 2009 | GPX ML648B MP3 Player
When I go to sync music from Windows Media Player, it says "It is not possible to change sync settings at this time. Try again later." What can i do to get it to work?
If you normally create a profile for your GPX on your desktop computer. Delete that profile, and then add back your GPX to your computer via the cable and it should work. I presume you are using windows XP?
Aug 14, 2009 | GPX MW3837 MP3 Player
Hello again
On the mp3 player, switch between the Usb and Mtp mode (The M button)on the side of the player
May 20, 2009 | GPX MW3837 MP3 Player
My MW3836 won't sync
try takeing it off of usb cable trune it on then plug it back in then sync
Apr 24, 2008 | GPX MW3837 MP3 Player
This is Kamunitsu. For Your GPX Audio Player-SD/MMc card in a memory card that slides in the side of your player. SD Translated as origin, (Side Card) Select Option: GPX Audio Player. And make sure that the code (or) storage type located in the memory file of your guide, make sure your player supports that file. The supported media player file and your GPX player file have to match in size, length, and Type.
WOULD YOU LIKE TO KNOW MORE...
Mar 28, 2008 | GPX MW3836 MP3 Player
GPX MW3837 trouble synchronizing
If you get the MTP on your screen and your trying to sync it with your computer just press and hold the usb/mtp button and your computer will reconize it [=
Nov 26, 2007 | GPX MW3837 MP3 Player
GPX MW3337 sync problem
1- Check that your MP3 Player's File system is OK, you can do that using the DOS command (chkdsk /f). 2- Re-install your Windows Media Player 11. 3- Don't forget to update your system, too.
May 30, 2007 | GPX MW3337G
121 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
