Question about RCA Scenium D40W20 40" Rear Projection HDTV
Have an rca scenium rear projection. Bug between screens. How can I remove outer screen to clean?
premtech
  • 934 Answers
SOURCE: picture doesn't fit screen
Go into the menu and select picture settings and then advanced picture settings. I'm not sure on that model that you can manually change the aspect ratio from zoom to 16:9 or 4:3 ect... But select Auto Format and the TV will pre-select the correct format for viewing..... Any questions just let me know. Bill
Posted on Jun 11, 2007
SOURCE: proper way to clean rca rear projection tv screen
my tv repair man said use a blackboard eraser and rub it on screen vertically - that is up & down only. He said to use no chemicals or cleaners, or you'll ruin it. He had a customer that had a child draw on it with crayons-he told her to leave it there because it's better than destroying the screen.
Posted on Jan 22, 2009
  • 1030 Answers
SOURCE: RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Posted on Apr 04, 2009
TODDAS
  • 431 Answers
SOURCE: rca rear projection fuse blown
U NEED A E-PROM
Posted on May 12, 2009
SOURCE: shadow on upper left corner
A little late and you've probably already solved it or are just living with it or are disgusted with it and have discarded the tv. But, in any event - here we go. The "light tunnel" bends the light toward your screen. At the beginning of that tunnel there is a plastic lens. The lens is secured with four little feet that a part of the lense. The lens is flat on the side closest to the screen. It fits on the end of the light tunnel closest to the light. The lens probably has a burnt spot. Probably the burn is caused by excess heat which is either a result of a fan failure or a one-time situation where the power went off while everything was hot and there was no cool down cycle. Another item to look at is in the light path before that lens. There is a small "window". It's actually a very thin piece of glass (about 1"X1") held in place by a horseshoe shaped clip and one screw. I think that glass has the purpose of keeping heat away from that plastic lens. If that glass is broken I think you'll have a heat "leak" and the plastic lens will continue to get worse.
Posted on Aug 05, 2009
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
How do i fix little bug looking spot on tv screen?
Can you elaborate a little? On the screen? Is it an image issue? Is there something on the outer glass? Or something between the two panels?
Jul 01, 2010 | RCA HD44LPW165 44" Rear Projection HDTV
Grey spot on screen
It's not the lamp. It maybe dirt or dust or even a bug. The picture that is projected starts out 1/2 inch by 1 inch in size. Somewhere along the path to the screen a piece of dust gets in and after it's projected it looks like a blob on the screen. The closer it is to the DLP chip itself the bigger it looks. If this is the case you should have a professional service it. The Light engine needs to be removed and cleaned.
If you lightly push on the screen does the blob move slightly ? If it does it's not on the screen it's in the optics or the mirror.
You may also have a bug or smug on the main mirror that causes the same thing. This will appear about 2 times the normal size of the object. If your up to removing the screen Take a look closely at the mirror on the back of the set. You can clean this with windex it's glass. If you do take the screen off hold it up to the light. Sometimes spiders make webs and leave marks.
Good Luck
Apr 19, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Front screen
Hi, much easier to access the front screens (there are 2 sandwiched together) by removing the top back cover, be prepared for lots of screws and when you get down to the last 2-3 screws get some help, on the inside of the back cover is a large mirror, some are made of mylar, do NOT clean or even touch a mylar mirror, the others are made of real glass and the back will be much heavier than you think (and very expensive if you break it)once the back is removed you should have access to the bug, good luck, video-tek
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Monitor strip down got a bug dead on inside of my screen
HOW CAN I REMOVE THE PROTECTION SCREEN TO CLEAN A DEAD BUG BETWEEN DE PROTECTOR AND SCREEN TV
Aug 11, 2008 | RCA HD52W59 HDTV Projection Television
RCA p56926 replacement screen
you cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
May 25, 2008 | RCA P52926 52" Rear Projection Television
Blue on the left and right sides of my rca scenium, 65 inch hi def rear projection tv
Well what may have happened is a bad thing, See if you can find some way of displaying a totaly white pix, and have this full size filling the entire screen. If the side bars are still there this means the CRT's are burned and this is a perminate thing, The fix would be to change the CRT's mabe just the green and the red but they still run about $285.00 each. This was cause by having the set run in a format that DOES NOT fill the entire screen
Jan 12, 2008 | RCA Scenium D40W20 40" Rear Projection...
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an rca scenium
turn off autoformat in customer setup
Feb 25, 2007 | RCA Scenium HD65W20 65" Rear Projection...
RCA Scenium D40W20 40" Rear Projection HDTV Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
