Question about Locks & Locksmithing
Hi there, I installed a Lockwood 001 deadlock yesterday but I can't get it to work. I tried the key with the door open and it retracts the bolt and deadbolt just fine, but when the door is locked
  • monty king Jan 09, 2013
    It's not an electronic keyless lock- its a Lockwood 001 Deadlatch
SOURCE: I HAVE AN OLD (20 YEARS) KWIKSET DEADBOLT
I think you are at the Wrong END, you need to be inside...
Posted on Mar 13, 2010
SOURCE: brought new keyless dead bolt. Put it in a door
there is a strap inside just below the battery compartment and you need to strap the opposite two that are strapped now. this will allow the bolt to operate correctly.
Posted on Aug 30, 2010
  • 15 Answers
SOURCE: powerbolt lock yesterday. One problem
That a mechanical problem.. Indeed, you'd better replace the key cylinder with a new one
Posted on May 15, 2011
  • 963 Answers
SOURCE: When locking or unlocking using the power it
This sounds like an unusual problem, but your lock may be covered under warranty. Warranty covers mechanical and finish defects, but not the internal electronics. I recommend calling them-- call 1-800-327-LOCK (5625) in the U.S. and Canada.
Here is a link to Kwikset's website for your reference, and you can follow a link to their written warranty, etc.:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Posted on Aug 15, 2011
  • 963 Answers
SOURCE: Just installed keyless entry lock. Lock button
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
Good luck-and please provide feedback if this helps!
Posted on Nov 05, 2011
The round metal piece outside the door where the key is inserted to open the door of my Lockwood deadlock is loose, how to tighten it please
go to the inside of the door and tightened the 2 screws from the back that holds the lock in the door.
Jan 12, 2015 | Cars & Trucks
How do I change the code on a lockwood digital door lock 530
First determine the code you want to use; find the tweezers and spare red and blue tumblers if you are going to change the length of your code. The factory-set code is 5 digits. You can only use each key once and the C key cannot be included in your 4-6 digit long code. Next you need to disassemble the lock with the lock kept horizontal during the recoding process. If the lock has been installed, you need to uninstall it from the door. Remove the two mounting screws from the interior face plate. Then separate the exterior section from the spindle connecting it to the interior face plate. If the lock has not been installed or the previous step is done, remove the adapter plate from the back of the digital lock (exterior plate) if it is fitted on the unit. Next remove the four red screws that hold the back plate onto the lock and remove the backplate. Press and hold the C button at the lower left (as viewed from the back where the tumblers are) below the most of the other keys on the faceplate. With the tweezers, remove tumblers and put a red tumbler in the spots corresponding to your new code. Put a blue tumbler in the all of the other spots. Make sure that the color side is up and that the square cutout is facing the side of the lock. (Thus on the right side keys, the square cut faces right and on the left keys, it faces to the left.) When all of the tumblers are in place, release the C button. Test your code and check that it works after replacing the backplate and adapter plate but before putting the lock on the door. Save the tweezers and additional tumblers for future code changes.
The directions for resetting the code on any Lockwood Digital Lock are provided in the service manual here: http://www.lockweb.com.au/Local/AU/Technical%20Downloads/Lockwood/Mechanical%20Digital%20Locks/530%20Digital%20DX/Lockwood%20DX%20Digital%20Service%20Manual.pdf . Other details for the lock installation are available here: http://www.lockweb.com.au/en/site/lockweb/Lockwood-Products/?productId=948353 .
I hope this helps.
Dec 04, 2014 | Locks & Locksmithing
Interior door lock won't lock with twist
If the bolt extends fully when the door is open, the problem is with the strike hole in the door frame. (If the bolt doesn't extend when the door is open, it's either a bad installation or a bad lock. Read the instructions again and reinstall it or get a new lock.)
If it used to work, open the door and tighten all the hinge screws before you do anything else. They could be loose even if they are covered with paint. This solves about half the problems with doors and locks.
The easiest way to figure out where the strike hole should be is to use the "lipstick trick." Extend the bolt with the door open, and scrap a tiny ridge of lipstick on the top, bottom, and both sides of the bolt so the lipstick will hit the doorframe before the metal of the bolt does. Retract the bolt, close the door, and try to extend the bolt a few times so the lipstick leaves a mark on the edge of the hole or somewhere inside the hole. Retract the bolt all the way before opening the door so you don't smear any marks on the frame. Now you can see where the problem is and what needs to be moved, or filed, or cut deeper.
Every woman who wears makeup has lipstick she bought and cannot return to the store. She will be glad to give you a tube and get some use from that awful color.
Mar 16, 2014 | Kwikset Locks & Locksmithing
Honda civic stuck in deadlock can't open any doors as the key won't work in any of the door lock's or boot
Try having a new key cut using the key code, at a dealer, not tracing the old key.
Feb 25, 2013 | 2003 Honda Civic
How do I lock the door with the key pad? I can unlock it fine but I can't get the door to lock. Don't have the manual. what buttons to I press?
Push the Lock button on outside touch pad to extend latch bolt 1" which locks the door when you leave.
Enter your desired personal code to retract the latch bolt completely which unlocks the door when you return home.
The T-turn on the inside of the door is used to extend (lock) or retract (unlock) the latch bolt when you are inside.
Using the key from the outside will also extend (lock) or retract (unlock) the latch bolt.
This Touchpad Electronic Deadbolt should be accompanied by a Kwikset Knobset, Leverset, or Handleset.
I cut & pasted the above from the installation instruction sheet.
Here is the link to the entire installation instructions sheet (manual):
http://s7d5.scene7.com/is/content/BDHHI/40486-02
It is a .PDF file, so if you aren't able to view it, download and install Adobe Reader from this site first:
http://get.adobe.com/reader/
If you are not able to lock the door using the outside touch pad's lock button, you may need to reprogram the door's "handedness", which gives the lockset the ability to be used on doors that have their hinges on either the right or left side of the door (right-hand or left-hand door).
The instructions for that are found on Step 4.9. This is also an excellent time to change the batteries, which is recommended yearly.
Aug 01, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I have Lockwood deadlock[20years old] which has come loose. I don't know how to remove rear cap to enable me to get to the screws, the rear cap has 2 holes in it which I assume cover the retaining...
Try turning the inside cylinder with the key. When the "holes" line up with the screws, insert the appropriate screwdriver and tighten them.
Dec 26, 2010 | Locks & Locksmithing
Volkswagen t5 caravelle central locking not working deadlocks on!
Turns out the problem was a broken wire at a junction below the carpet below the drivers seat. Took my mechanic 4.5 hours to fix it nightmare had to take seat out handbrake lever etc to get to it!!
Jan 19, 2010 | 2004 Volkswagen Eurovan
Door knob to garage won't open. The "bolt" won't retract.
If all else fails...take pins out of hinges and remove door to get to lock bolt.
Sep 07, 2009 | Amerock 3 Ring Knobs - BP1586
My front door has a Roto R627 lock. I can't get
If the deadlock moves a little bit, The deadbolt may not be lining up with the hole. Put some lipstick on the deadbolt tongue and try to turn it. Then check where it is hitting the frame. You might have to just tighten up the hinges to shift the door position.
Jul 03, 2009 | Locks & Locksmithing
Baldwin 6321 mortise:when locked can open from either side
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Feb 02, 2009 | Hardware & Accessories
Locks & Locksmithing Logo
486 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
