Question about Transtherm CR212104 Wine Cooler
COOLER TEMP CONTROL SEEMS NOT TO BE WORKING.  TEMP GOES DOWN TO 42 AND STAYS THERE.
  • 700 Answers
Thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Posted on Jan 21, 2009
McQuay PTAC stops working after short time
Sounds like you need a new control board with thermistors. you probably have a relay that is getting hot and quitting.
Sep 19, 2014 | Heating & Cooling
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
The blower on the cooler stays on, won't cut out.
Possible that the thermostat is not working, ry reducing the control down to see if the cut off takes place.
It there is no action, shut offfor 8 hours and check witha lower settings. If the unit goes on , then you have to check the thermostat and control for fault.
Sep 24, 2010 | Hamilton Beach Water Cooler with Storage...
Set temp to 42 and 54 but unit stays at 75. HELP!
sounds like the compressor is not running . ck the connectons at compressor and listen for a click in the cold control as it may be bad .. / noises like clicking at compresor . may be the relay that starts it .. mm
Aug 09, 2010 | Danby DWC283BLS Wine Cooler
Freezer runs constantly,seal is okay,frost free,have tried lowering the temp,food stays frozen. zeecudaboro@tds.net
It seems to me that the thermostat is no longer sensing temperature. IT will either stay on (it controls the compressor) or wont come on at all when it becomes a problem. You can order one thru sears.com if there is not a appliance parts store nearby. To check before buying, heres what you do. You need to know the temperature (use a thermometer that reads below zero). it has to be at least 10 degrees or cooler. if it is then turn down thermostat dial to 1. if it shuts off then the thermostat is ok. if it doesnt turn off (the compressor) replace t'stat. let me know the temp. and if this works for you hope this was helpful...
Mar 30, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Keeps running and freezing eveything, replace temp switch still freezing up
No the temp wire should be not on top of the coil but running down the middle all the way down to the bottom of the cooler. Try this first and if it doesnt work let me know
Jun 02, 2009 | True TD-65-24 Commercial Refrigerator
Not staying cold all of a sudden
THE PROBLEM NEEDS THE ASSISTANCE OF A TECH THER MIGHT BE A PROBLEM WITH THE GAS CHARGE OR THE COMPRESSOR NOT PUMPNG EFFICANTLY.GOODLUCK. MOHAMED
Jun 22, 2008 | Danby DWC283BLS Wine Cooler
Temperature light control (kegerator DKC645BLS)
Not sure u have a problem.. all appliances dont HOLD a certain.. Temp.. They cycle.. come on for awhile reach a temp the shut down.. goes so low the comes back on... the middle of the cycle is the avarage temp... yours being 36 from what you posted
Sep 04, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Jul 31, 2007 | Danby DWC513BLS Wine Cooler
Transtherm CR212104 Wine Cooler Logo
285 people viewed this question
Top Transtherm Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Transtherm Refrigerator Expert? Answer questions, earn points and help others
