Question about Samsung SyncMaster 912N 19" Flat Panel LCD Monitor
The screen in blacked out but computer is on and monitor powered
It seems to be in some type of hibernation mode or something. I am out of town and my kids are trying to get hoemwork done. Please send me a fix asap if possible---- Thanks!
    Master:
  • 461 Answers
Shut down the PC, unplug the power cord and press the power button to discharge the mainboard, wait several minutes and reconnect the power cord and power system up. Even if this works there still may be a video card and/or other hardware problem.
Posted on Jan 21, 2009
Dell Inspiron 6000 New Hard Drive, Now no Hibernate or Standby
Try to enable hibernation from command prompt
Click on start click run type cmd then ok, black screen will appear then just type command:
powercfg /hibernate on
If there is a problem with PAE we gonna need to disable PAE
Feel free to ask for questions
Jun 05, 2010 | Computers & Internet
When turned on says no signal and screen does not light up is there a reset button this is monitor that is being switched to different computer HP computer
PC may be in hibernation mode or with power plug out f PC remove refit video card if it has one.
Try booting into safe mode then disable hibernation mode found in "power options"
Dec 04, 2009 | ViewSonic VX900 19" Flat Panel LCD Monitor
My Toshiba Satellite L305-S5877 will sometimes go into a "sleep" type mode randomly and the screen goes almost completely blank. I can just see what is on the screen very faintly. I checked and...
You have to disable the hibernation mode. Sounds like this is the problem. Go to Start - Control Panel - Performance and Maintenance - Power Options - click on Hibernate tab and uncheck where it says Enable Hibernation. This should fix the problem. Cheers
Oct 02, 2009 | Toshiba Satellite L305-S5877 Notebook
After hibernate mode monitor blinks on and off. The monitor is on power is being feed to monitor however if you turn the power button on and then off the picture on the screen will blink on and then off
If it is your computer that is in hibernation then blinking on the monitor light is normal
Just bring your computer out of hibernation and the screen will come back to life too
Aug 22, 2009 | Dell Computers & Internet
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
Digital Power Saving Mode
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Nov 30, 2008 | LG W2252TQ Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Monitor hibernation problem
Mine does the same( fp567s). Lay screen face down and tap GENTLY fixes mineSuspect loose connection at power board ,too lazy to look
Oct 28, 2006 | BenQ FP567s 15" LCD Monitor
Samsung SyncMaster 912N 19" Flat Panel LCD Monitor Logo
264 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
