Question about Lenovo G560 06793JU Notebook
Hard disk and cd drive are not detected
I couldn't enter to windows. when I check on BIOS Hard disk and Cd drive not detected. Could you please Help!
    Master:
  • 397 Answers
Hi, First of all I would check they are both connected. However it's quite unlikely they've managed to both disconnect themselves at the same time.
Assuming they are both connected ok I would first remove one or the other, then enter your BIOS to see whether the remaining device is detected. As these devices will often be run by the same controller, if one is faulty it could cause the controller problems and in turn it would fail to detect the healthy device. If you can now see the remaining device in the BIOS you can be left almost certain that the removed component is at fault.
Should the BIOS still fail to detect anything this could indicate a controller failure on the mainboard. To help confirm this I would try and connect a drive or ROM that you know is healthy and see if they detect in the BIOS. Another way to help confirm this would be to boot from a USB device into some kind of OS (Windows, Ubuntu etc) and see if the controller is detected by the OS. If it doesn't detect the controller this would be further evidence it has failed.
In a situation where the controller has failed it is often best to pursue replacing the mainboard in the laptop. However it can often be more economical to replace the entire machine.
Posted on Jan 09, 2013
WeListen2You
  • 538 Answers
SOURCE: How to format and install a OS into the HARD DISK using a PEN DRIVE ......
nope..that is a complete compatibility challenge of the first order..
Posted on Oct 13, 2008
TamirMeiri
  • 94 Answers
SOURCE: Lenovo C100 will not boot to bootable CD
Hello brush71, it most likely is.
I suggest going to BIOS and trying to enable the cd drive.
If not possible, perhaps there is a hardware failure.
As you've described a problem with the Hard-Drive as well, I would suggest, if warranty is still applicable, to turn to your nearest Lenovo lab and have the computer fixed.
Posted on Oct 29, 2008
len52155
  • 20 Answers
SOURCE: i have lenovo Y410 laptop i have deleted all the
did you recreate the partitions you deleted? sounds like there's not a partition on the drive. when you boot the machine press the F1 key. that will take you to the system bios.. then press F9 .. that will set the bios to the factory default settings.. then press F10 that will save and exit the bios. If you have a partition and its set active..you should be able to procede from there. If you continue to egt the error message.. you need to verify the part5ition is valid and active. formatted would help as well..
Posted on May 19, 2009
elix0411
  • 3530 Answers
SOURCE: I have Lenovo R60. There is a problem while loading windows xp.
There might be a minor system glitch on your system. Perform a system restore in you system and restore your computer from the date where it is working fine then observe. If same issue will occur then you need to send it to our repair department for further checking.
Posted on May 30, 2010
cross123
  • 383 Answers
SOURCE: Hard Disk drive do not appear in Disk Management & Device Manager
to fix the problem you must open your laptop check the hardware inside of your laptop hardisk thats the problem try to unplug cables of hardisk to plug again or replace new hardware hardisk if not solve the problem
Posted on Jun 18, 2010
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
The computer is having trouble finding the hard disk.
The problem could be a faulty hard disk or a faulty disk controller.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 27, 2012 | Computers & Internet
I have hp pavilion dv 2000 laptop, during windows xp installtion the massage comes that setup didn't find hard disc drive installed in your computer. what is the problem???
Here is the User Guide http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Most likely the hard drive is bad.
To check power on the computer and enter BIOS by pressing F10 (Just keep hitting F10 until it enters BIOS)
Go to the system configuration menu And boot options, if no hard drive is listed then it is bad and needs to be replaced. You can attempt to unscrew the back pull out the hard drive and re seat it(plug it back in)
Also in BIOS check for Enhanced SATA mode and make sure it is off or in compatibility mode. Windows XP never shipped with SATA support and will result in a blue screen error during install. So turn off enhanced sata mode and it will run as an old IDE interface so to speak.
Jul 12, 2011 | Computers & Internet
I have a note that says, " no bootable device found, please insert bootable disk then press any key",
The laptop cannot find the boot hard drive, it may be faulty or just need reseating to make proper electrical connection.
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 29, 2011 | LG X-Note LM50 Notebook
My laptop wont start up, It says "system disc or non system disc error, replace and press any key.." why? :(
you have it set to boot from cd so when you startup the computer it attempts to read the cd and than boot an operating system for you either remove the disk or enter your bios menu and set your boot order to negate the cd drive
Oct 25, 2010 | Computers & Internet
My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
Just keep setting till you put at the right position where the system recognizes it.
There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
Take care.
Jan 04, 2010 | Maxtor Hard Drive
System failure to boot
  1. Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
  2. Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
    - Floppy drive
    - CD drive
    - Hard drive
  3. Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Feb 03, 2009 | HP Compaq Presario V2000 Notebook
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Sep 26, 2008 | Computers & Internet
Lenovo G560 06793JU Notebook Logo
120 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
