Question about HP ProLiant ML110 Server
Sata condroller driver - HP ProLiant ML110 Server
  • HP Master
  • 2,878 Answers
Is part of the OS. Based on the model look for the F6 key to press during install. That means you have to have the drivers on a separate disc. They used be available at HP as a floppy image. Or use a new install disk of Windows, like XP SP3 w / SATA or Windows 2003 SP2.
Posted on Jan 10, 2013
Please, give me a Sata driver for this HDD
The driver you need is for the onboard IDE/SATA controller. Locate the make and model of your motherboard, visit the support site that they have online, download the driver for the IDE/SATA/RAID (if applicable) controller.
Mar 24, 2014 | Fujitsu 40GB MHW2040BS SATA Mobile 40 GB...
Sata drivers pt80c-alx boot
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2013 | Computers & Internet
Sorter jammed and does not sort machine makes thumping noises canon np 6551
BMW 530i fuel pump condrol rilay How is the program that one
Sep 06, 2011 | Office Equipment & Supplies
COULD SOMEBODY HELP ME , I HAVE FAILURE KODE F 14 IN MY WASHING MACHINE
F14 = EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU. If there is an error reading this data, it will cuse this error.
* A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
* Check CCU
Apr 23, 2011 | Dishwashers
MY Compaq Presario CQ40-330TU doesnot installing XP software
Hi
You need to have xp cd with sata disk driver support.
You can make xp with sata driver verymuch easily by downloading sata driver from intel site or other site and merging with xp cd.
Inorder to merge xp with sata driver you need to use the nlite software whcih can be downloaded from .http://www.nliteos.com/
For guide for creating xp with sata use this link http://www.nliteos.com/guide/
For sata driver u can use this link http://www.zyxware.com/articles/2008/10/07/compaq-presario-cq40-108tu-laptop-drivers-for-windows-xp evenethogh it is different model sata driver will be same and it will support for this model also
Mar 01, 2010 | Computers & Internet
Sporadic grinding noise driver's side. 2001 Dodge Dakota quad cab 5.9l I have replace both cv axles.
check the outer bearings and if it is while you turn the wheels check uger strut mount and condroll arm bushings
Jan 10, 2010 | 2001 Dodge Dakota
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
Change geteway laptop from vista to xp
Yes you can but disable the SATA in the BIOS first and after Xp is installed you can install the SATA driver.
XP does not have a SATA driver or a SCSI driver on the CD and you need to interrupt the install process to insert this driver.
Leave the BIOS set to SATA, download the SATA driver and create a floppy with the SATA driver. Boot up the Windows XP install disk and when it asks for a a hard disk driver press F6 (I think it is this key, you have to be quick) insert the floppy with the SATA driver.
May 03, 2009 | Gateway M-6834 Notebook
HP ProLiant ML110 Server Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
