Question about Dell 2300MP Multimedia Projector
Need help from malaysia
The projector fell on the floor. Lens cannot be adjusted but there's still picture on the screen. Picture very blur and the lens is not adjustable. The problem i am facing is I am in Malaysia and this LCD was given by a friend from USA. How???
    Brigadier General:
  • 6,966 Answers
Hi, From your description/post, I will assume that it is a mechanical problem rather than electronic (since it is still working though blurry). If you would like to try and fix it yourself, you have to disassemble the focus mechanism of the lens. This should be rotatable to enable you to adjust the focus on different distances to the screen. This would require that you use some tools and extreme care specially in the alignment and position of the various parts. It operates in principle like the adjustable focus of the manual film type cameras, speaking of which you might find that a camera repair man in your area might be able to do the job for you. Good luck and kind regards.
Posted on Aug 07, 2007
Projector angle to high
You should be able to adjust the "position" of the picture through the menus. There are also "keystone" settings that may be adjusted to make the picture fit properly.
Nov 10, 2013 | Sony VPD MX10 Multimedia Projector
Projects blurry picture onto screen even after adjusting the focus. It is an EIKI Diamond Projector LC-SD10.
Did you connect signal with native resolution 800*600
blurred picture can also be caused by extreme contamination of optical parts
Aug 22, 2011 | Eiki LC-SD10 Projector Multimedia...
Have an LCD projector viewsonic PJ513D. We can't see well on screen.. the display is blur.. can't see anything.. What could it be?? THe lamp time used till now is 696 hrs. Please...
You need to adjust the focus lenses ring until the picture is no longer blur. It is like in the old manual film camera, some model and brand have autofocus which can adjust thru setting. So try to adjust it.
Enjoy your viewing!
Jun 07, 2011 | ViewSonic PJ513DB Projector
I have a mitsubushi hc 10 the picture is blurred what is wrong?
Adjust focus of a projector.
Make sure a projection screen is at least 4.1' (1.2m) from the projector.
Check Projection Lens to see if it needs cleaning.
NOTE : Moving a projector from a cool temperature location to a warm temperature location
may result in moisture condensation on Projection Lens. In such an event, leave a
projector OFF and wait until condensation disappears.
Apr 02, 2011 | Mitsubishi HC10U Multimedia Projector
The picture is blurred
Have you tried tweaking the lens, you should be able to rotate in and that is generally the reason for blurry picture (out of focus)?
Feb 28, 2011 | Acer PD112 Multimedia Projector
Picture is too big for screen, projector wont zoom enought to fit screen
you will need to move your projector closer to the screen. you will need to zoom all the way out and physically move your projector closer to the screen and then adjust your focus.
Jun 01, 2010 | NEC PROJECTOR ZOOM / THROW LENS, 1.2 TO...
Camera fell on the floor (carpet) and now the
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Casio Exilim EX-Z750 Digital Camera
Blurry picture
You need to clean the projector lens on the optical engine using a soft cotton or, better yet, a chamois cloth. Also clean the mirror mounted inside the rear cabinet and also the front and rear of the screen itself.
If picture is still blurred then your the optical engine is most probably defective.
Dec 10, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture on viewfinder is blurred Everything in my viewfinder is blurred, even the numbers and stuff in there. The picture I take isn't blurred.
I think your camera has a diopter adjustment. If it does, it'll be located on the right side of the eyepiece. It's a small wheel with a + and -. Adjust that until the image is clear.
-or-
It's possible that it is in need of cleaning. If you plan to remove the focusing screen, be exceptionally careful not to scratch it. Has it been subjected to extreme moisture conditions?
Aug 31, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Picture is not sharp.
Sounds like one or more of your LCD panels is out of adjustment and will need to likely go back to the manufacturer for repair.
Good Luck,
John
Jan 08, 2008 | Philips Bclever Sv1 Multimedia Projector
Dell 2300MP Multimedia Projector Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
