Question about Kodak EasyShare Cameras
Battary charge level not disply inthe screen - EasyShare Kodak Cameras
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, I don't know the model of your camera but it sounds like this indicator has been turned off in the system settings. Check the user manual to find how you turn it back on. Can't be a serious problem.
Best Regards, Russell
Posted on Jan 24, 2013
try to empty the battary and after a 15 min charge the battary and try to reboot.
May 17, 2014 | RaueSoft Reboot Manager Widget
I have a Poulan 18 HP 42" deck; battery would not charge so replaced it with new. Now starter gear will not engage with teeth on flywheel, sits just below engagement level and just spins. Suggestion
Most starters will have a bendix shaft, once the motor starts to rotate the gear follows the bendix thread up into the fly wheel ring gear, so there is either not enough charge in the battary, or the bendix on the starter motor is bad, or the gear itself is bad, or the battary is wired up the wrong way.
Feb 10, 2013 | Poulan 42 In Deck 165 HP 6 Speed Manual...
Not power on and battary weak
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 13, 2012 | Nokia 2730 Cell Phone
I have a big problim with mt 91 honda accord my battary wount charge i put new altanater new battary all cables are great but it wount seem to charge the battary if i charge the battary it well last up to...
With the engine running are you getting any voltage off the alternator? check with a multimeter. Check voltage at battery while running should be 13 volts or more.
May 16, 2010 | 1991 Honda Accord
I have battry problem with nokia 6233 battary is bp6
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 12, 2010 | Nokia 6233 Cellular Phone
Hello i replace my small ups 650VA battary with a car battary,when i charge the car battary with an external charger does this affect my ups if it remain connected with the battary
Should not be a problem - just make sure the charger is a good one, and avoid over-charging. Once the battery is fully charged, the UPS should maintain it properly. Also, check the water level once a month - dry cells will kill the battery.
May 04, 2010 | PC Chips M871G Motherboard
I have canon zr800 camcorder,its battary not gatting charged.
can you try to used a new battery if it works i think your old battery have a problem.
thanks,
Jun 23, 2009 | Canon Video Cameras
I have q phone its battary doesnt take the charge
Check if its the right battery because it might be the wrong one
Apr 02, 2009 | Motorola Mobility Q Smartphone
Cameras Logo
15 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
