Question about Acer Aspire Computers & Internet
! network controller
Help my wirless wont work i have tryed everything
See that your answer is that open my network then see that their is any setup a wireless ntwork click on it and then type networkname(ssid) and then click on automatically assign network key then click on next after that there are two method 1st usb flash drive and 2nd setup a network manullay but you have to choose 2nd and click on next then your process is completed
Posted on Jan 09, 2013
Roblem with the drivers for network conncetion
Try going into the wireless control in you Control Panel. Doing this manually has helped me override doing it from my taskbar.
Aug 12, 2012 | HP Computers & Internet
Wifi
have you installed the wifi drivers compatable with your device and operating system? go to device manager find network adapters. update drivers and choose browse my computer and then choose let me pick from a list of drivers. then select from the lists given update driver and u should then be able to go into the control panel and under network and internet open network and sharing and manage wirless networks or change adapter setting
Dec 11, 2011 | Computers & Internet
IBMThinkPad T40 Wont connect to wireless networks.
Hello, if you see a yellow exclamation mark it means device drivers are not installed or are incorrect.
below is the link for IBM/Lenovo site that lists all the drivers for Thinkpad T40/T41. Go to that linkand scroll down to " Wireless Networking" and select the appropriate drivers: eg: Make sure it under T40 section, and not T41 since they are listed side by side.
since i am not sure which exact wireless card your T40 has i am posting this main link where it lists all options.
I would start with "ThinkPad 802.11bg wireless LAN Mini PCI adapter" if this doesn't work try next one in the list.
here is the link: http://www-307.ibm.com/pc/support/site.wss/MIGR-46258.html#wireless
I hope this helps, let me know if there is a problem.
Kind reagrds,
Amar Sondhi
Jan 22, 2010 | IBM ThinkPad T40 2373 Notebook
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
Wirless networking
The red line through the icon indicates that that network adapter is disabled in the device manager. (You can enable it by right clicking My computer, choose Manage>device manager. But the realtek is used for your ethernet cable connection. The 1394 connections are network adapters used for network connections to printers, etc. probably left over from your work setting, and can be disabled for the moment.
You don't mention what OS you're using, but I'll guess XP, and provide another link for vista just in case....
In any event, it's going to be necessary for you to reconfigure your network connection to the router/gateway you're using at home to connect to your ISP. Here's a general wireless networking troubleshooter, in the event that you've already covered the basics. And here and here are articles/links that will give you more advanced guidance. (Also here.)
But here and here are links to basics: to help you set up and maintain a network in xp, and here's an alternative for vista.
Another excellent resource to help you answer questions and troubleshoot the connection is this site, which has specifics that deal with many common ISPs.
In the end, you may find the easiest thing to do is start at the beginning by setting up a new home network and working through each step to establish a new connection.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 23, 2009 | Computers & Internet
Wireless router cannot connect to XBOX Live
I have a linksys 10/ 1000 card and a 2wire wirless router and had the same problem. You need to go to your control panel and double click the wireless network. Once you set it up you need to make sure that if you have a firewall that the xbox has permission to access the net. Also all wireless devices have a security measure some have WEP keys and others have passwords you need to find out what yours is.
Jul 20, 2009 | Microsoft Xbox 360 Console
The wirless network i was getting on doesnt let me on anymore.
you might have to configure your settings on your stick again or even router!
message me or let meknow if you want further help
Jan 13, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Computers & Internet Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
