Copier misfeed when i'm doing my photocopying, halfway through it stops printing but the drums or the toner sound continues like i'm waiting for more printouts to come out but nothing comes out. when the sound stops, the copier alerted me of 'misfeed in copier'. open the side cover but there's no paper jam. just have to pull out that one paper that apparently stopped printing (don't know why). close the cover and the printing resumes. then the same problem occur like mentioned. never had to encounter this problem before. help??
  • 15 Answers
SOURCE: DCP 7020 Brothers laser printer paper jam & back cover open fault
Try doing the following prior to messing around with the fuser itself:
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002000/000024/faq002024_006.html?reg=us&c=us_ot&lang=en&prod=mfc7820n_all&Cat=4
Posted on Jun 13, 2009
SOURCE: My copier continues to misfeed even though I have cleared the jam
there are little plastic fingers on the drum and heating rollers (hot), one of those is raised up from the surfaces of either component, causing your paper to catch. both move back and forth on tiny springs. on the fuser you can actually remove several of these fingers if they are the problem and still use. on the drum they must be repositioned or replaced
Posted on Aug 05, 2009
  • 5603 Answers
SOURCE: Printer error shows paper jam at paper tray and
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Posted on Dec 16, 2009
  • 6 Answers
SOURCE: Photosmart C3180 keeps saying paper jam or
Click Here To See A List of Solutions from HP!
Posted on Jan 09, 2010
  • 3 Answers
SOURCE: orange light flashing - won't print
have you got a reset button on your printer if so try pressing it down and holding for a few seconds put some paper in and try again
Posted on Mar 25, 2010
The photocopier keeps flashing a red light and have no manual
If light is blinking it can mean a few things like the toner/developer (TD Cartridge) needs to be changed soon or the drum needs to be changed or there is a paper jam or misfeed of paper.
Nov 04, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have ricoh aficio mp 2000, it's photocopy print black lining
if it background like faint toner all over copy need to replace developer powder/drum/blade/gears
Oct 08, 2011 | Ricoh Aficio MP 2000 Black and White...
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
Incoming fax does not print, and also cannot get printout of faxes received. Memory was received. Regular printing and photocopying works fine.
if you found the msg on lcd like "toner empty" & red light near the lcd
then you have to reset toner counter through tech mode.
MENU # 1 9 3 4 MENU pres continues you will find tech mode on lcd
then press 3 times right arrow key "new cartridge" will come on lcd bottom line
then press 2 times ENTER button & swicth of the macine for 5 second then on
all samsung mfds stop printing FAX when "TONER EMPTY" msg comes.
Feb 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
HI, MY XEROX 1045 COPIER has making ""clicking"" sound
That indicates you need to replace the drum cartridge. It's been a while since I supported those products, but I believe the cartridge is in the bottom of the device. Make sure you remove the toner cartridge before tipping it over or you'll have a mess to clean up and won't be able to remove the drum.
Once you replace the drum, you need to reset the copier.
Nov 17, 2009 | Xerox Office Equipment & Supplies
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Paper a misfeed
not sure if you are talking about two papers jammed in different locations or at different times?
first thing would be to clean the tires that pick up the paper, if too smooth then replace. sounds like a timing issue.paper getting stuck halfway in the fuser c(if no other paper jammed) can be Seperation is off causing the paper to rise onto the drum creating a time lapse, paper tansport belt (in the machine after the drum) is not turning ok, or as simple as wrong size paper Letter in machine but says Legal 8 1/2 x 14
Aug 26, 2008 | Ricoh Aficio 1018D Copier
Smudge marks on paper; otherwise normal
fuser is usually replaced as a assembly, it's the hot bit a back.
Can only be two things the drum or the fuser as our headstrong friend has correctly explained.
More than likely it is the drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine
Jan 07, 2008 | Brother HL-2040 Laser Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
21 people viewed this question
k24674
