C-c152 in bizhub c450 - Office Equipment & Supplies
Nitrotrike
  • 589 Answers
SOURCE: bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
Posted on Feb 10, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
rcampsr
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Posted on Apr 06, 2009
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
Error c3451 for bizhub c450
Error c3451: "Heating roller warm-up failure"
Oct 12, 2014 | Konica Minolta 120v Fusing Unit For Bizhub...
How i can rest error code c-d231 on bizhub c450
CD231 in Bizhub C450 come due to missing of DIMM memory board in Fax board.
in service mode(Utility-counter-Stop-00-Stop-01) -system2-option board-unset the Fax1 and fax2 and re-start machine .
Jul 03, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Bizhub C450 touchscreen doesn't work
You need a new touch screen panel or I/O cable, they are fairly expensive if you don't have a service contract with your Office Printer supplier. Recently just replaced one a few months ago.
Nov 28, 2012 | Konica Minolta bizhub C450 Touch Panel...
Feb 20, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
158 people viewed this question
jasbo
jasbo
