Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Kitchenaid superba range low flame
We have a kitchenaid superba range that is aproximately 5 years old. Previously the front left burner flame was substantially lower than the other burner that is the same size. At some point that burner regained it's strength but now the right rear burner is doing the same thing. Any ideas?
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
  • 625 Answers
SOURCE: burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Posted on Aug 30, 2007
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
  • 126 Answers
SOURCE: GE Range JBP82 Has 2 Burners Not Working
Could be bad infinite control switch.
Posted on Jan 02, 2009
  • 59 Answers
SOURCE: viking range - gas flame on one burner does not change
It sounds like the repair man was correct. The only variable is the valve, if the rest of the burners are fine then it will be the valve
Posted on Mar 09, 2009
Kitchenaid superba gas stove left front burner will not operate unless back left burner is turned on at same time
The switch for that particular burner is bad. It turns out that whenever you switch on 1 burner, they all spark - that's a safety feature. Depending on the model, you may just need to replace the 1 switch, but usually, they are part of a switch string, and you have to replaced the whole string of switches..
Nov 19, 2014 | Kitchen Ranges
Smell of gas and excessive flame when using Superba
First thing to check is whether the stove is for LP or natural gas. Takes a different orifice size on each type of gas.
Nov 15, 2017 | Kitchen Ranges
Low flame on left front burners high flame onright front burnners
That is food/grease buildup. Clean the holes. TURN OFF GAS to stove, then just clean the holes in the burners with a soft wire brush. Then turn gas back on and immediately relight pilot lights. If that sounds scary, call your gas company, they might come out and help.
Dec 09, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Adjusting front (most powerful) burner on kitchenaid (Left front)
There is an air port near the adjustment knob. Open for a more blue flame and close for a yellow flame. If these haven't been moved before, you probably have a clogged jet at the burner. Just clean it out with a pin.
Feb 04, 2012 | KitchenAid Blenders
I have a Kitchenaide model KGSS907SBL01 gas range. Everything works fine except that we find that the amount of heat generated is disappointing. This seems to come from the fact that the top of the grill...
It would seem like reasonable thing to do.However the adjustment is typically for the low setting so you can adjust just the small flame just enough to simmer a pot without the flame going out from being so low its susuptable to going out on the low setting, also it so you can adjust the flame smaller so on low it isnt too high,causing it will boil when you intend to only simmer a dish your cooking. A question;is it all burners and have they always been that way?
Aug 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
335 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
