Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do i set the door limits for the coromaster mach 11 motor
3 Suggested Answers
CutOnTheNet
  • 14 Answers
SOURCE: How do I reset my garage door opener. It is a
The Coromaster 2000 does not operate off limit switches. It has a quarter-revolution optical pulse counter. To re-program the open and close limits do the following: Ensure that the door is open at least a couple of feet. Press the reset button once or twice Short out pushbutton and common and hold until close limit and then release. Door should stop at your new close limit. Wait 5 seconds. Short out pushbutton and common and door will open. Hold the short until open limit and then release. Limits should now be set.
Posted on Nov 09, 2010
  • 3197 Answers
SOURCE: i have a coromaster march
Try this place.
http://www.ileadgaragedoors.co.za/tag/garage-doors/page/8
Posted on Mar 22, 2011
My coromaster door does not want to open by remote. It just makes a beeping sound.
have you changed your batteries lately, this is consistent with a bad remote or low battery
May 31, 2015 | Building Materials
Coromaster garage door motors limits
When in doubt, Google it. If this gear attaches to a chain, it gets a little difficult to keep the chain in control. Usually parts like this are held in place by a set screw, requiring the correct allen wrench. Working this stuff up on a ladder is no fun.
Nov 24, 2013 | Building Materials
How to programme remote for coromaster 2000 garage motor
Jun 14, 2011 | GPS
I have a Coromaster Mach2 garage door opener. How do I code a second remote? Thanks
This appears to be something made in Africa. I suggest you call around locally. We don't seem to have any around here.
Jan 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Dryer was working perfectly then just stopped working. I am getting the proper voltage from the house. Have proper voltage going to motor and door switch is working properly. Have checked the nuteral...
check the thermal switch it is located on the top of the heat chamber in the back of the mach. you lift the top of the dryer and it will be on top in the back right there will be to the thermal swith and the high limit thermostat they have to be replace as a set
Jan 06, 2011 | Maytag MDE308DAYW Electric Dryer
Hi, My glidermatic gts keeps going open once it reaches the bottom, everything works; it?s just it keeps going open. I have to close open, close open until it stops in the close...
The Glidermatic GTS 2000 has limits that are stored electronically.
The problem you have is the closing limit is set too low and needs to be adjusted so the door is just resting on the concrete - currently it is trying to drive through the concrete, the motor detects and obstruction and reverses.
If your Glidermatic GTS 2000 was supplied & fitted prior to April 2010 you can download the 'Limit Setting' procedure on the Gliderol website. If the unit was installed after April 2010 it MAY have a revised PCB known as the NGTSv2 PCB. Contact your local branch for limit setting procedures as they are not yet available to download online.
The combination of a mechanical door and electric motor means periodical adjustment is required to esnsure the travel limits and - most importantly - the sensitivity is set correctly. A service to your DOOR is strongly recommended every 12 months.
I hope this helps
Jan 03, 2011 | Garden
Remote control for Garage Door ML 850 won't operate
I have just been fitting mine today as well.
Same problem - you have to wire the infra-red bits (I just blue-tacked mine facing each other and wiried them as explained and placed on top of the control box to check this worked)....and it does..
Cheers.
Oct 27, 2009 | American Standard Home
How do I reset my garage door opener. It is a Coromaster 2000 motor. The closing and opening setting are out and the motor only stops due to resistance.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
