SOURCE: Glass Stovetop
"F1" is an Electronic Oven Control (EOC) Board failure error code. The top stove functions will continue to operate normally, but you probably will not have any bake or broil capabilites as this board controls all your oven functions. This is a very simple repair that you can accomplish yourself, but the price may be something to consider.
Searspartsdirect.com has the part listed under the "Backguard" heading as item number 20 (part #316101001) and lists for $174.
Repairclinic.com has the part listed as item number 496226 and lists for slightly less at $170.
If you do not have a warranty or service plan in place, you, unfortunately, will have to suffer the cost. If you wish to pursue this as a do-it-yourself repair, let me know and I will give you easy step-by-step instructions on how to replace it. I hope this helps you. Let me know if you have further questions.
SOURCE: glass top is scratched no matter what I do. oven doesn't work ri
glass top stoves are not designed to do canning on, sorry. the only thing you can do for the top is that special cleaner as it has a "wax" in it and will help to prevent stains, but not scratches.
remember your top is glass and it will scratch.
your oven can be calibrated to help it to bake better. what you need to do is make sure you have a temperature problem that can be corrected by calibration. try to just set the oven temps up or down 10 or 20 degrees and try to bake the same items. if this helps then you can reset the calibration of the control as per your owners manual, if you dont have one then i can tell you how if you can tell me the brand and model.
SOURCE: Scratches on glass stove
Is it glass or ceramic? there are special cleaners for ceramic tops check walmart, lowes, or where ever you bought that one they can tell you.
SOURCE: Drexia clarifying previous post on gas range stovetop cleaning.
I have found that kitchen cleanser and a crub pad along with good old fashioned elbow grease is your best bet...
The fine scratches might come out with a good rubbing compound like the type used on car finishes...
SOURCE: cook top burner is scratched suface seems to be
Sorry but no repair to remove the scratches. Only way is to replace the top which is very expensive.
