How to replace bearings on hotpoint wt740 washer drum
How to remove the drum and replace bearings for hot point washer model wt740
  • 139 Answers
SOURCE: changing bearing on hotpoint FEW12??
welll its a long job.
first remove the top
then the front control panel.
disconnect any wires connected to the circuit board.
then remove the front panel with the door intact. to do this you must unscrew the the screws in the top and bottom and remove the screws for the door inter lock as well as undue the door gasket from the panel.
Then you got to remove the concrete weights. and pull the pegs in the legs from the drum side.
Then you got to dissconect the drainage at the bottom of the drum from the pump
remove the wires from the solenoid and disconnect the pressure switch from the small plastic tube.
undue the tubing from the soap draw to the drum
remove the clips near the springs.
undue the front metal panel which the board was connected to and remove the drum
if you need anymore help dont be afraid to ask.
Posted on Dec 16, 2007
stradeteox
  • 88 Answers
SOURCE: replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Posted on Jan 08, 2009
barkencoa
  • 3463 Answers
SOURCE: How to I remove the drum from a Hotpoint WM64
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Posted on Sep 04, 2009
Testimonial: "Your solution answered my question, but left me with another. How to remove the bearings from the drum. "
  • 5 Answers
SOURCE: how to change drum bearings
Right - all washing machines are pretty similar except between manufacturers such as Dyson, who use such things as three seperate drums.
The average washing machine is simply a motor attached by a belt to a drum, with a programming unit that connects to a door sensor and heating element, and a seal that goes around the drum.
Since we are dealing with Hotpoint, the first thing to do is take off all panels from the front, the top, and the back.
From the front: You will be able to see your drum, and should be able to undo the seal. Basically at this point, unscrew everything attached to whatever I describe - remembering where they go. Now the front seal is sometimes attached to the case that surrounds the drum - usually with a heating element attached to it on some models.
From the back: You will see the belt attached to a flywheel that turns the drum. Rotate the drum to check that the rumbling / banging noise is still occurring. Check that the drive belt isn't damaged or worn as this can cause problems. Unscrew the huge bolt that holds the flywheel on to the drum (rotate anti-clockwise). This will usually take a lot of force and is better to use a large spanner, lock it in place, and turn the actual drum with your hands if you can't undo it. Now when this comes off, you will be able to pull the drum free. Move it around until it comes away. The bearings may drop off the drum's shaft so retrieve them. Check to see if they fall apart as this indicates the bearing's seal has gone totally. This is the part to replace. Buy a replacement the exact same size for your model of washing machine and reassemble - ensuring that all screws go back in the right place.
Hope this helps. Remember that it is just a case of unscrewing things in the right order. You learn best by just doing - so if you are mechanically minded - this sort of thing will be a doddle. If you get stuck and can't remember how to reassemble it - call out a repair man and watch how he fixes it as this will of course allow you to try it if it goes bad again ( a common problem I've been told with Hotpoint and Zanussi models since they are manufactured using cheaper parts than others. )
Posted on Nov 09, 2009
  • 153 Answers
SOURCE: Replace drum bearings on hotpoint aquarius wf000g
You really don't want to know how but here it is. The bearing is located in the rear shell and is not removable the rear shell has to be replaced which means removing the tub assembly from the machine and completely disassembling. With 30 years of appliance repair the last one I did took about 3 hours.
Posted on Feb 26, 2010
My hot point wma bearing is gone. Where to buy spare ones.
Depends where you live here in England I buy from hotpoint.however its quite a big job to do also you may find this models bearings are sold on as half drum,you need to buy he half drum with bearings fitted to replace and costs parts approx 70.pounds..hope this helps
Jul 01, 2012 | Washing Machines
How do you replace the bearings in the drum?
It involves a complete strip down of washer,literally down to the last nut and bolt.
Some models have one piece tub assy, so it is not possible to change the bearings.
Remove the top cover, and see if the drum is a one piece assy, if it is not, you should be able to see the screws securing the 2 drum halves together, if you cannot see any screws, then the whole outer tub assy has to be replaced, an expensive repair!!!!
tTo change the bearings, the whole tub assy has to be removed from the cabinet, and then the drum has to be split to gain access to the bearings.
Until you get to this stage , you will then be able to determine if the drum shaft is worn, if it is then this will have to be replaced.
All in all a long expensive repair to undertake.
Take my advice, and if the washer is more than 5 years old, then buy a new one.
Good luck.
Nov 07, 2010 | Hotpoint WMA48 Front Load Washer
Feb 25, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Fault code stopping washer from working
My washing machine will not spin and in fact turn around at all, i did a wash earlier and it was making a funny noise...like some thing was caught in the drum. It is about 3 years old....It does still fill with water thou!
May 24, 2009 | Ariston Technologies Washing Machines
Removing transmission top bearing
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Mar 29, 2009 | Hotpoint VBSR3100D Top Load Washer
How do i remove and replace drub bearings
There is no no easy way to get to them, as it involves a complete strip down af washer.
Briefly, you have to remove top and front panels, disconnect all electric wiring, and remove the whole of the inside drum assy from the cabinet, then you have to split the inner drum, before you can get to the bearings, not a repair to be undertaken lightly unless you know what you are doing.
Good luck anyway.
Plz rate my comments.
Thanks.
Jan 08, 2009 | Hotpoint First Edition FEW10P Front Load...
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Very noisy
The washer is not a sealed unit but the rear drum bearing are also you will need a new spider...To take a look inside - Initially you will see enough from the top to see where things are...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If the Drum bearing has failed it is usually due to over loading or a faulty seal in the drum, water leaks into the inner bearing. This causes corrosion and then ultimately failure.
In the likely event that the bearings have failed (I have had a hotpoint wma33 fail at 23 months...) Its actually cheaper for you to pay hotpoint to fit a new drum (Parts are free for 5 years! you just pay a flat callout fee - believe me its a bargin). + they never ever replacing just bearings, it takes too long for them. They will do a whole drum and spider arrangement in under 2 hours...
I wasted 3 days because these things are really awkward to remove and refit. The callout fee for a hotpoint engineer a fixed cost. I bought a spider see:
http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=954798&brand=&model=wma33&part=spider
This spider costs 61.25 + delivery - ouch.
I bough a half drum thinking I would keep the costs down. Hotpoint will fit half a drum or full drum (Depending on what is on the van for their call out fee) the actual cost of a half drum is 75.99 + delivery see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639770&brand=&model=wma33&part=drum
and a full drum costs 161.49 + delivery
see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639763&brand=&model=wma33&part=drum
They take away all the rubbish at the end also!
I know this site is about doing it yourself and I can go into more details about how to do it. But because I did not have the correct tools that hotpoint must have to pull the bearings from the housing etc - I feel I would be wasting your time.
I hope this helps
Please don't rate me as unhelpful, this is not a simple change the bearings task.
Jul 06, 2008 | Hotpoint WMA40 Front Load Washer
Hotpoint wm80 bearing replacement!!
The drum will have to be removed.
Bearing replacement on ANY Hoover can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Hoover washers require at least 2 specialized tools for removing certain components of the machine.
Jun 26, 2008 | Hotpoint Washing Machines
Washing Machines Logo
161 people viewed this question
Top Washing Machines Experts
