Blowing luke warm sometimes and hot others
MAC 22608 Intertherm electric furnace that will blow luke warm air sometimes and then nice and very nice and hot others... my husband has put everything over onto one breaker and that is when it will heat like it is supposed to but when using two like it should it is refusing to heat like it should... blowing out luke warm air...barely warm at all... 65000 btu ...completely lost...need help
  • 700 Answers
You have a bad breaker and need to replace it. when you put the load all on one you are taking a chance on having to replace both of them. Thae are not made ot be shut off and on to manty times.
Posted on Jan 21, 2009
My furnace come on and blows luke warm air but will not blows hot
You need to check the flame sensor. There is a wire that tells the unit when the burner is on. The burner may be coming on and then gets warm and shuts off, then the fan comes on. It could also be the upper limit temp thermostat that is tripping but since you did not post the make and model, it is hard to say
Dec 17, 2017 | Cars & Trucks
The heater on my 98 ford expidition blows hot air at first and then blows only Luke's warm. If I shut heat off and turn back on it will blow hot and then turn Luke warm why
-Sounds like the system is clogged or the on off valve is not open
properly.
-Check the valve and flush the system. It should be good to go.
Good luck
Mai
Nov 22, 2016 | Ford Cars & Trucks
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Intertherm furnace parts
if its electric heat one of the sequencers or elements out
Jan 04, 2014 | Intertherm Heating & Cooling
I have a coleman in my modular home, dosent blow hot air, everyth
Check the air filter and clean. If you can, raise the blower speed up to the next speed. Make sure all of the supply and return grills are open. Is the ductwork connected under the home and well insulated? Does the furnace ever stop or keep on running? If it does stop, you may have a bad thermostat.
Jan 03, 2010 | Coleman Heating & Cooling
The Intertherm AC Model B3BV-030K-A is blowing warm air
If you don’t see any frost on the suction line or big line on the furnace
(that goes from the furnace to the outdoor unit) and the filter and coil are clean then you are probably low on refrigerant.
Apr 14, 2009 | Heating & Cooling
Electric furness blows hot then warm
if this has happened since you got hte furnace it is normal
heres how a heter works
themostte tells heater to turn on
heating element turns on
followed in about a minute by the blower
during the peried before the blower kiks on the elements become supper heated
after the blower kicks on it slowly leves off the element temp and air temp coming out
Jan 23, 2009 | Hunter Fan Company 5/1/1 Programmable...
Intertherm furnace not getting hot after motor swap. PLEASE HELP
You already diagnosed it yourself. The motor may have been the same physical size but it operates at a higher speed and doesn't remove enough heat from the furnace. You need to have the right motor installed period.
Jan 17, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm heat pump blows hot then cold then hot
You may have a problem with a temperature safety system.  Before changing anything else, check to see if the unit is clean!!!  Dirt/dust can fool the safety system into an overtemperature status.  Inspect the heat coils for damage and dirt.  Gently clean.
Nov 23, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
