Question about Zanussi Dishwashers
SALT EMPTY ALERT
I DON'T HAVE THE MANUAL AND THE SALT EMPTY LIGHT IS ON AND I AM UNSURE WHAT I NEED TO DO. i AM HOPING THIS WILL HELP WITH THE WASH AS DISHES ALWAYS SEEM TO COME OUT DIRTY ON THE TOP SHELF
  • 8,197 Answers
You can get the manual here. You will need to know the model # though. I looked at the first manual and it will show you how to fill the salt.
http://www.usersmanualguide.com/zanussi/dishwasher
Good Luck and please Rate FixYa!
Posted on Jan 21, 2009
Low salt alert. Add salt turn back on and then says high salt. Wait till evening try again says low salt again. Already cleaned copper and salt cell. What's wrong.
for starters, the default 'something is wrong' will turn on the salt light. never add salt until you do a manual test. once you determine that the salt level is right for your system (in range) you might find that the cell itself may be the problem
Aug 15, 2015 | Pool & Spa
I want to know where to put my dishwasher tablet in my Kenwood KDW4TTSL please. And where does the salt go and how much do I use?
Im presuming that you don't have a manual. If you would like one, you can download a free PDF from here:
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
According to the manual:
There is a recess on the right hand side of the door for detergent (Picture on page 6 of the manual). You can put a tablet in here.
With regard to salt (Also on page 6):
1. Unscrew the cap from the salt container
anticlockwise, which is located on the right side of the
inner box.
2. Load the salt into the container. Each time you may load 250g of salt, which can be used for 15
cycles.
3. Fill the water into the salt container until a small amount of water comes out(it is very important
when you use it for the first time).
4. Screw the cap back carefully.
Note:
1. Load the salt before the beginning of wash cycle so as to prevent corrosion.
2. Load the salt when the salt indicator light in the control panel is illuminated.
3. Only use dishwasher salt.
Jul 19, 2011 | Kenwood KDW4TTSL Dishwasher
I am getting a error code of 92 on my intex swg. I have put 4 - 40 lb bags into a 15 x 48 pool and brushed the bottom to distribute the salt evenly. I left the pump on for 24 hrs and then set the swg for...
I installed a new Intex ECO 8110 unit on my 15' above ground, steel sided pool. After about 10 hours of use I had the "code 92' high salt alert that shut the system down. I knew that my salinity wasn't high because the local Pinch A Penny pool store does free water analysis and i was given the okay just a week prior. We had also received a bit of rain in the interim so I knew that the alert was false.
Here is how I fixed the problem (so far).
1. Turn your unit off.
2. Disconnect the power cord from the outlet and wait for 2 minutes.
3. Unscrew the retaining nut at the electro-cell connector and unplug the connection.
4. Rotate the plug 180 degrees to reverse the polarity of the plug and re-connect to the electro-cell.
5. Reconnect the power cord to your receptacle.
6. Turn the unit on, wait for the green light to burn steady.
7. Monitor for the next 5-10 minutes.
My unit has worked flawlessly for 3 hours. If i receive another "code 92" alert i will repeat the procedure which will result in bringing the unit back to its original polarity.
Jul 01, 2011 | Intex Automatic Salt Water System for ...
Dish washer wont wash properly
You should check the levels for the salt and rinse aid they need topping up weekly if your dishwasher is used a lot,when the machine is empty give it a good clean with kitchen spray all around the door and underneath the panels you will be surprised how much gunk gets stuck in their ,also clean out the filter ,when all sparkling run the dishwasher on empty to give it a good wash out, do this on its hottest setting ,if this does not work then you will need to get a technician out.
Jun 02, 2011 | Electrolux Dishwashers
Machine does not want to start on any cycle.
Check salt chamber and add salt if empty. Check your inlet water flow.
Apr 14, 2010 | Dishwashers
Milky residue and a dry salt pot after each wash
It sounds as if there is a blockage in the salt matrix / inlet. This can happen if the wrong type of salt is used.
The simple answer is to use the expensive tablets/pods - that include salt. This will improve the wash and hopefully the blockage will free eventually.
Fill the salt container with water regularly to try and help dissolve it - no salt untill it's clear.
If it doesn't clear within a month - it may need stripping and clearing manually - or continue with the premium tablets untill something else breaks - requiring a service.
Aug 28, 2009 | Zanussi 18 in. DE4744 Free-standing...
Problems with my bosch dishwasher
there should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Jun 12, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
268 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
