Question about Acer Aspire™ T180 PC Desktop
I disabled my video adapter by mistake now all i see is windows logo but after boot up its a black screen cant see to log in or anything...tried starting in safe mode but it wont start up
    Master:
  • 461 Answers
Boot into safe mode (press F8 while booting for options menu) then go into device manager and re-enable the display adapter or uninstall it and allow Windows to reinstall it when you reboot.
Posted on Jan 21, 2009
Black screen on booting
Hello dhauser451, does you computer boots to windows or does your computer has a black screen and will not boot or no logo screen, no windows, no startup, but still running ?
Maybe your windows boot screen disable?
NO GUI boot - System Configuration
Please reply back if you want me to help you.
Nov 26, 2010 | Nvidia GeForce 6600 Graphic Card
My latitude d600 wont start up!
hi, your windows explorer is corrupted. to solve this, simply insert the xp installation cd and boot from it. then run repair to fix the os. note your files will not be lost
Jan 24, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
The graphic software failed. no display
When you turn the computer on, do you see the HP logo?
If you don't, keep the computer on and try holding the computer screen under an overhead light at an angle. If you see a faint image of anything on your monitor, then the lights in your screen went bad. A new screen can range $100-$200 on eBay, and can be changed out easily with a small Phillips screw driver.
If you can see the HP logo, it's a driver problem. If this is the case, start the computer in Safe Mode by performing the following steps.
1. Make sure the computer is turned off.
2. Wait for the HP logo disappears and start pressing "F8" repeatedly.
3. A menu will appear. Select "Safe Mode" and let it boot up to the desktop.
4. Once at the desktop, hold down the "Windows Logo" key on the keyboard and press "r". A dialog will pop up.
5. Type "devmgmt.msc" without the quotation marks and click ok.
6. Click the "+" next to "Display adapters".
7. Right-click each entry under "Display adapters" and select "Uninstall" Click OK on the box to confirm. Don't worry, Windows will reinstall it after a reboot.
8. Once all entries are removed from "Display adapters", the category will disappear from Device Manager. Reboot the computer and start it normally.
9. Your screen will probably still be big and blurry. Log into Windows and adjust your resolution to fit your screen. If you select the wrong resolution, and your screen goes black or does not fit, DO NOT PRESS ANYTHING or you will be going back to step 1. The computer will revert back to the old setting after 15 seconds.
10. Once you figure out the right resolution setting, reboot one more time to make sure that the settings took effect, and you can use your computer once again. :)
Oct 25, 2009 | HP Pavilion dv6000z Notebook
Screen on laptop keeps going black
please explain further. keeps going black from where? after turning on the laptop? of after windows logo? if after windows logo screen turns black if a no boot issue where laptop cannot load system files. if screen is black after turning on no manufacturer logo and windows logo or anything then it might be the LCD or video card / motherboard. to isolate try connecting your laptop to an external monitor and check if you will be getting the same problem. if no display from the external monitor then its a video card issue, if video card is integrated needs to replace motherboard.
Oct 01, 2009 | Computers & Internet
Screen issue
Boot to Safe-Mode by pressing the "F8" key several times when you first see the windows logo screen. Answer "yes" to enter safe mode. "Right click" on "My Computer", select "Manage", then "Device Manager". Expand "Display Adapter" by clicking on the "+ sign" on the left side of Display Adapters. Highlight the Adapter listed under the Display Adapter line by "left clicking" on it. Then press the "right mouse button" and select "uninstall" to uninstall the display adapter. Now reboot you system (not safe mode) and see if it works. The display text may be very large now. If it works, you need to find your drivers cd that came with the computer and install the video driver using the above procedure but selecting "update driver" instead of "uninstall"
May 28, 2009 | Averatec (620060HD) (620080HD) Hard Drive
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Windows log on
You can try logging in as administrator.  As the computer starts up press 'F8' to get into the boot options and select 'Safe Mode with Networking".  Click on the administrator login, the password is blank unless you set one during installation.  Once in windows you can modify the user accounts in control panel.
Note:  If you have never used "F8" to get to the boot menu before the timing is a bit tricky.  If you see the windows logo you are too late. Try pressing "F8" several times instead of just holding it down
Nov 28, 2008 | Microsoft Windows XP Home Edition
I disabled my video card now i cant see the screen???/
Where did you disable it? In windows? Start up in Safe mode and check your video there. I would ininstall it and restart. Windows should see it and set it up normally.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 10, 2008 | Acer Aspire™ T180 PC Desktop
Booting up windows xp pro on dimension 4700
hmmm..not too happy..sounds like your video card is not too good...try it in safe mode(F8) and then check the video card in control panel, then system, then device manager. make sure driver is clean.
got backup?
Feb 19, 2008 | Dell Dimension 4700 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
