Question about NAD Audio Players & Recorders
How do you Bridge a NAD 3100 with a 2100?
I'm trying to bridge a NAD 3100 with a 2100 and need to know where the inter connect cable/cables go.do I leave the lower inter connect in the 2100?
Technotch
  • 22 Answers
SOURCE: Bridge RCA Thomson DCM315R
Usually cable providers provide public ip directly to your company ( already bridged ). so no need to configure your modem to bridge.
- Connect the computer directly to the modem and if possible, let me know the ip address of your PC, So we can find the modem already bridged.
- If its already bridged, then Open the ports on your Router ( port number : 3389 for TCP ) or else you may try DMZ Host on your router to check whether it works.
Note:
DMZ ( Demilitarize Zone ) host which opens all ports on your network and shows ur computer to the outside Network which is not really secured one. but you can try it for testing purpose whether it let you to use remote desktop.
Hope this will help you
Posted on Oct 25, 2007
osborne382
  • 306 Answers
SOURCE: bridge jbl gto 600.1
it will over heat the amp posibly blow it.....becareful
Posted on Nov 12, 2007
SOURCE: Using a wireless bridge for Dreambox
i dont think it has wirless on it mate but j tag it
Posted on Apr 19, 2008
Duncan
  • 218 Answers
SOURCE: on lucent amps you sometimes
I'm not sure if Lucent has a special bridging procedure, but on most if not all other amps, when you bridge you DON'T connect two terminals together. What you do is instead of using the plus and minus terminals on one channel to one speaker and the other +/- terminals to the other speaker, you will instead use the plus (+) terminal from one channel and the minus (-) terminal from the other channel to drive one speaker and the remaining + and - terminals remain unconnected. Be sure you use the + and - terminals that are marked for bridging. Please note, that when you bridge that your speaker load DOUBLES to EACH channel. In other words, what your amp saw as a 4 ohm speaker going to one channel alone, it now sees as a 2 ohm speaker on each channel when bridged. Be sure you know what you are doing before you bridge and fry your amp. In my experience, if after bridging your amp works fine for about a month and then fries then you bridged wrong and ended up with the wrong speaker load on each of the bridged channels. Be careful. Amps cost a lot to repair. Good luck.
Posted on Jun 03, 2008
frcs68
  • 1605 Answers
SOURCE: Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Posted on Dec 30, 2008
Window cable came off
I managed to get the cable back on the track but it took multiple tries and then to find out that the plastic bridge was broken ( the piece that connects to the window has a plastic connector(bridge) that holds the 2 cables one to bring the window up and one to bring the window down. well that connector was broken. To access that part you need to bring the window down so the "bridge' aligns with the hole in the track and you'll see where the two cables come together but it you can only see the bridge from the back. Maid really cheap by GM. Sorry I wasn't much help.
Dec 09, 2013 | 2002 Buick Century
How to bridge NAD 7150 with 2150
Bridge connections
Using 2150 as a slave
Sep 09, 2012 | NAD Audio Players & Recorders
IF I HAVE A MOTOR WITH STAR DELTA WINDING AND NO LABELING IS DONE HOW WILL I CONNECT THE CABLES TO THE MOTOR
the motor will have 3 pairs that can be checked with a ohm meter for continuity. each pair has a start and a finish. usually it would be labelled U1 V1 & W1 for the start and U2 V2 & W2 for the end or finish.
To connect in star ( Motors that start with direct load ) supply cables to U1 ( Red ) V1 ( White ) W1 ( blue ) and bridge out U2 V2 & W2.
To connect in delta Supply cables as above. Bridge U2 to V1 - Bridge V2 to W1 - Bridge W2 to U1.
If you have a reversed winding the motor will growl and not turn.
To reverse direction of rotation swap any 2 supply cables ( But only when the power is OFF )
Mar 09, 2011 | Kitchen Ranges
HOW DO I CONNECT MY BLU RAY PLAYERS BDP S360 & BDP S1E TO A COMPUTER AND INTERNET ??? WHAT TYPE OF CABLES SHOULD I USE FOR CONNECTING THESE TYPE OF PLAYERS TO A COMPUTER ??? THANKS !!!
With the BDP S360 there is a port titled 'LAN'. With this port you need an ethernet (RJ45) cable which you can plug into your router or computer. If you plug it into your computer, you will need to bridge the connections to send the internet connection through the LAN cable. There's a good tutorial on how to do this here: http://helpdeskgeek.com/windows-7/bridge-network-connections-in-windows-7/ OR for XP: http://www.home-network-help.com/network-bridge.html
As for your BDP S1E player, you are unable to connect it to the internet.
Good Luck! -AC
Jan 05, 2011 | Televison & Video
Reset bridge to different router without the disk.
Follow these steps :
•1
Reset the bridge. Accomplish this by manually disconnecting the power source from the wall or the back of the bridge. Leave it disconnected for 30 seconds to a minute so that the software contained therein can fully reset. Reconnect the bridge and wait two to three minutes until the network is back up and running again. In many cases, a simple reset can solve your network-related bridge problems.
•2
Ascertain whether there is network activity on your computers. Accomplish this by looking at the back of each computer at the network card. There should be two lights next to your Ethernet port--at least one of these lights should be completely lit without flickering. This indicates that the network card in the machine is operational and ready to receive a signal, eliminating that as a possible problem source.
•3
Move the bridge to a different location to determine whether interference is preventing the network computers from receiving a proper signal. If possible, relocate the bridge to the same room in which the computers are located and try to reset the connection again.
•4
Determine whether the bridge has failed altogether or whether the wireless signal from the bridge has failed. Accomplish this by physically connecting the computers to the wireless bridge through the use of Ethernet cables. If this restores network connectivity, you know that the only problem with the bridge is the wireless signal emission.
Oct 01, 2010 | Computers & Internet
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
How to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Jul 22, 2008 | Cisco Aironet 340 Wireless Bridge
How to connect two remote device with a phone line in between.
no, not with a phone line... you could but making a bridge connection with an utp cable... but with all respect, if you were thinking about a telephone cable you are surely not qualified to do that bridge without assistance... so i recommend the following.
You surely know that UTP cable (lan cable) supports a distance up to 90 metres which is about 295 feet. If you need to go outdoor for that connection i would recommend outdoor cable for that connection its very cheap... and you dont need two routers if you just have four computers tops...
other stuff like amplify antennas might help your reach the far away computer via wireless...
other way is to find info on how to build a bridge with two routers on the net by searchin on google, its not that hard, but you still need utp cable... never phone line.
Mar 17, 2008 | Computers & Internet
Dropped connection
Step 1:
Connect the Wireless-G Music Bridge to your router using an Ethernet cable. For instructions, click here.
Step 2:
Access the Wireless-G Music Bridge’s web-based setup page. For instructions, click here.
Step 3:
When the Wireless-G Music Bridge’s setup page appears, scroll down to the Wireless section and look for Wireless Mode and select Infrastructure.
Step 4:
Look for the Wireless Network Name (SSID) field, enter the wireless network’s SSID.
If this doesn't work let me know
Aloha
Bob
Dec 13, 2007 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Note:
Sep 19, 2007 | RCA Cable Modem DCM315R (11603540)
59 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
