Question about Sony Playstation 3 (PS3) Console
Have to force game in ps3
Its seems weird... I have to push a little on the disc for the ps3 to accept the game. Is there any way to fix this?
...this is normal, it's not a problem.
Posted on Jan 22, 2009
My ps3 wont accept any disc. try putting it in but it stays there. Also when i try to put it in the blue light comes on but the game is not in the system, and when i push the blue button afterwards, it...
Hi Sef,
If you are getting the YLOD or yellow light I will run through what causes it and how you can fix it.
The yellow light is caused by internal overheating and the main chips that take the damage are the GPU and the CPU.
You need to stop the heat build up and you will be able to get back to gaming again.
You can either send the console back in for repair and they will fix it for you, however it will take about 4 weeks to get this done and it will cost about $150 for the repair!
Quicker Solution:
For a faster way to fix it you can use a good YLOD Repair guide that will show you with videos how to stop the heat build up and get back to gaming.
The important thing is to make sure that you get a guide that is up to the job!
I have put together a list of the best PS3 Repair guides and a complete review below:
Click Here To See The Best PS3 Repair Guides
Hope this helps.
Other Problems That You Can Fix Today Are:
PS3 Freezing Up
PS3 Will Not Read Games
PS3 No Display
PS3 Error Codes
PS3 Red Light
PS3 Red Screen
Check out the full site and get a 1 hour solution...
Sep 12, 2011 | Sony Playstation 3 (PS3) Console
It seems that the "motor"
Hi david,
The disc reading problem is quite a common one!
It is caused by the laser coming away from the drive and you need to readjust the laser to get it to work.
Sounds bad but at least the drive is not broken JUST the laser needs readjusting.
Now let us look at how you can fix this:
Solution 1:
The normal way to fix this is to send it in and they will do the work for you at the factory. However it will cost about $150 and also you will have to wait about 4 weeks.
If you do not play on your PS3 that much this may be the best solution for you.
Solution 2: For A Faster Fix
If you want the games reading problem fixed quickly then you should check out some good PS3 Repair guides.
They normally include videos showing you how to readjust the laser - it takes about 20 mins.
Make sure you check out the full reviews below so you can fix a good one!
Click Here For A Full Review Of The Best PS3 Disc Reading Fix
Hope this helps and if so please leave a comment or if you have any questions let me know?
Mar 26, 2011 | Sony Playstation 3 (PS3) Console
When the ps3 turns on the blue light saying a disc is in it comes on and refuses to accept any discs at all and when i do manage to get the blue light off and put in a disc it has to be forced in and the...
The most common reason for the game not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!.
Good luck.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Video games stuck inside and wont come out but was working just fine before this
Hi,, here's the solution. Remember that you must NEVER force the disk out by using hard objects/screw driver/plier or anything to pull the drive out. This will wreck the PS3 and its drive.
• Turn off your PS3 from back (the main off button)
• Put your finger on the eject button and once you do, push the switch at the back to switch the PS3 on, and then push the eject button. Hold it like this for fifteen to thirty seconds, or until the drive is forced open.
• The disc should come out now.
Thanks and take care
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
Playstation wont take any disc it'l eject but not insert
i have seen this before... there is a little eye inside the ps3 bluray drive that senses when a disc enters and starts turning wheels with rubber feet on them to pull the disc in. when that eye goes bad for what ever reason the only way to get it to accept discs is to force it in slightly and it will spread the acceptance arms and pull it in. if it will not eject the disc correctly then the drive has been disassembled and needs to be reseated until it function right.
the acceptance eye is fairly cheap to buy online but can be a pain to replace if you dont know what you are doing.
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
PS3 will not read any discs
The laser lens might be damaged. Is your warranty still available?
Jan 29, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
