Question about Coby MP305 MP3 Player
Having trouble down loading musia to my mp3 audio player
I am also very upset that when I called tech I was put on hold for first 7min then disconnected then I called back but on hold for 11 minutes and recording says I was tenth in line, waited the ll min and then was told to call back later then disconneted. please help me I an an older
adult and not very good at this.
Thank you,
marta
  • bashfull762 Jan 21, 2009
    I down loaded from emusic.com/ coby and the down loads are on my desk top but i am lost from there i hook up the usb and the mp3 to the computor but cant seem to down load to the player
    I havent been helped yet hope i am not being billed for that answer
    Sergeant:
    Scholar:
  • 199 Answers
Http://www.freebyte.com/music/ just click the link and download the latest software of musica and it will work properly. thanks.
Posted on Jan 21, 2009
    Sergeant:
  • 378 Answers
What error does it shows while downloading and are you having proper software to be downloaded.
    Scholar:
  • 160 Answers
Wat exactly you want us to help for plse explain it clearly.
How do i add videos on my trio-v218 mp3 player
put in the cd it came with and it will install mp3 player utilities which will have a program called amv converter and load the video there and it will convert and load it onto to your device
Jan 25, 2010 | Digital Audio TRIO MP3 Player
How do i load pictures?
Plug in your MP3 player. Open MY COMPUTER, your MP3 player will show up in the scroll on the left side of the screen. Go into your documents to select an image and simply drag and drop ontop of the folder called ALBUMS under the GPX. This will put images into an album on the player.
To See the images once on your MP3 player,
1. Turn on the MP3
2. Hold MODE BUTTON
3. press up or down until you select PICTURE
Your images will appear as a list.
I find that .gif images and .jpg images work the best.
Aug 09, 2009 | GPX ML648B MP3 Player
Im having trouble putting videos on my coby mp-705 ths is the mo
download a converter or put it on i tunes and convert to acc or mp3 format
Jul 02, 2009 | Coby MP-705 Digital Media Player
Aux input for MP3 player
I'am an M.B. tech- I do not beleive that this radio is mp3 compatable- iknow that the input you are refering to is used for ipod use. It very well could be that the head unit has to be programed(basically informed0 for an mp3- i would call the service dept. and ask to talk to ther best audio tech savay mechanic. Most likley the service writer wouldn.t know or give you false information because they do not stay on top of all the little tecnical changes. This fiber optic system has many programing features- most have to be done with as sds laptop(dealer software only) good luck
Apr 05, 2009 | 2008 Mercedes-Benz Mercedes Benz C Class
RCA Opal 8G will not turn on
As long as the Hold switch is off, the only way to even attempt to fix this player is to reload the original firmware, which will delete your songs. You can also call RCA at:
1-800-311-9263
Mar 30, 2009 | RCA OPAL M4001 MP3 Player
Mp3 player won't load properly
It sounds like your mp3 player has whats known in the tech world as a lot of bloatware or crapware, as we geeks call it. Its extra software that companies put into tech gizmo's to sell their software. I usually try to remove the bloatware by deleting it from my gaget.
Jan 20, 2009 | XO Vision Audio Players & Recorders
Sansa fuze 2gb is screen is white
If you just bought it, By all means return it!  Otherwise call sansa tech support.  The're rather good for tech suppport people.  If you bought an extended warranty, the place you bought it from should replace/repair it and you troubles will be over!
-Aptera
Nov 24, 2008 | SanDisk Sansa Fuze MP3 Player
Computer not recognizing mp3 sansa clip
Comment by vickisanchez, posted on Mar 19, 2008 IT FINALLY WORKS !!!!
Sandisk Tech support had me do the following:
- Turn it OFF
- Put it in the HOLD position
- HOLD the center button IN while plugging into USB port, continue to hold for 5 to 7 sec even after plugged in.
At this point MY COMPUTER recognized it. And it worked.
He also had me to:
- go to WWW.MICROSOFT.COM
- In the upper right hand search bar, type in MTP PORTING KIT
I did this and downloaded the first one. Now my Sansa Clip work perfect. I wish I would have talked to him last week before I returned the last one, for the same reasons.
If this does not help call the 1-800 # , opt #4, and ask for GUY (yes that is really his name) out of 5 or so calls to Tech Support he is the only one who knew what he was doing, and how to actually HELP.
GOOD LUCK
Apr 09, 2008 | SanDisk Sansa Clip MP3 Player
GPX MW3837 trouble synchronizing
If you get the MTP on your screen and your trying to sync it with your computer just press and hold the usb/mtp button and your computer will reconize it [=
Nov 26, 2007 | GPX MW3837 MP3 Player
Can't connect!
Has to be Windows XP for either USB Mode but im not sure whether u can connect it to other computers under different versions of Windows or not and I know Apple computers dont work at all with the Sansa E200 series. Also connect ur Sansa to the rear USB inputs instead of the front inputs. Something that has to do with power distribution if none of these call their tech support they were very helpful with my issue.
Dec 25, 2006 | SanDisk Sansa e250 MP3 Player
Coby MP305  MP3 Player  Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
