Question about Dual MXD55 AM/FM/CD/Weather Receiver
Dual MXD55 W/6/5 SP CD Problems
Ok, so I took out the old JVC receiver and labeled all wires that I disconnected. I then connected the Dual MXD55 W/6/5 SP CD Weather Receiver and nothing.... The red light flashes, but nothing comes on. I push the power button, and nothing comes on. Does anyone have any suggestions?
  • 1 more comment
  • eye1eye Jan 09, 2008
    Installed MXD55 MARINE DUAL, all wires hooked up. Red light flashes and cd motor hums when reset pushed, but nothing happens when face plate is clicked in place. Removed prior dual, none marine, with similar complains. Not due to radios, so ????? problem?
  • RobKim Apr 27, 2009
    Has anyone fixed the blinking red LED problem. Mine was wired correctly and working fine the suddenly the red LED problem happen and the unit will not work.
  • kbutch311 May 24, 2009
    my dual mxd55 marine stereo will not play cd's. it says err02 and then kicks my cd out. i have treid mutliple cds, but the same thing occurs!
Why does the red light flash when accessory is switched off and the face plate is removed?
Will it drain the battery?
Posted on Mar 17, 2008
Make sure the speaker grounds are connected to the speaker ground wires on the deck and not the "chassis" ground. also make sure both power wires are hooked up to a power source. the thinner power wire is supposed to be a switched source (like the ignition key or an accessory switch) that turns the unit on and the thicker one is a constant source which actually powers the deck once the switched source is turned on.
Posted on Sep 18, 2007
SOURCE:
Hi...ihave acd receiver in my car and it turns on but in the display "chk wiring then reset" everithing is conected ok but nothing is working
its most likely a short in your speakers, try disconnecting all over the speakers leaving only the remote ground and power wire connected and see if it still has an error. if not, hook up each speaker individually and turn it on after each one, and once you connect one and it fails again youll know thats the bad speaker. if it still errors with the speakers disconnected then its almost certainly your ground, if thats the case youll want to find a bolt behind the cd player thats attached to metal and make a new ground wire.
Mar 18, 2013 | JVC KD-R430 USB/CD Receiver with Dual AUX...
Installing a jvc cd player into a 99 crown vic
the best thing to do is not to cut factory wires and buy a wire harness from walmart or miejer and the wires will be color coted match up and tape them up them plug the two harness's together that is the best way to wire up a aftermarket radio
Sep 24, 2012 | JVC USB/CD Receiver with Dual AUX Input...
How do I connect a JVC CD player KD-R716 to 2010 Hyundai getz?
you need to rewire if you have an old unitinstalled. follow wiring diagram of your jvc. cut old wires and connect it to your new jvc. adapt your new wiring by comparing
Feb 25, 2011 | JVC AM FM CD DET FACE CAR STEREO
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
How do i connect the wires to put in new cd player in 95 aurora
ok you nee d to go to walmart or your closest car audio center and purchase the wiring kit for your year model vehicle the kit will have the plugs to plug into your factory harness do not cut your wires these plugs will have the wires labeled wire them to your new radio and it should plug in and play you may also need to aquire a face kit for mountring the sterio
Mar 01, 2009 | Dual XD-7500 CD Player
Unit turns itself off after diplaying code "check SP wire"
My guess, guess, check CLOSELY the SPeaker wires - "Check SP wire" make sure all of the bare portion of the wire is into the terminal. No bare wire touching another bare wire both at the receiver and at the speakers. Also, if the wiring is not continuous, check all connections of speaker wire. Disconnect all but one, play it like that. If no problem, label that as good, disconnect another for several days, when one shuts Rec. off, check wires closely for that speaker.
Jan 23, 2009 | Yamaha HTR-5650 Receiver
Check SP wires
There is an internal short that is being detected. This is probably a defective output transistor that is somewhat sensitive to heat. This should be a straightforward repair with a parts cost in the $20 range. Add in the local labor rate for the total cost.
Dan
Jul 16, 2008 | Yamaha RX-V740 Receiver
Jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Sep 01, 2007 | JVC KD-PDR30 CD Player
Car Audio & Video Logo
282 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
