Question about Ricoh Aficio 450 Copier
Ricoh Aficio 2018 copier is giving error code SC320
    Problem Solver:
  • 10 Answers
Replace laser polygon motor or laser unit
Posted on May 11, 2013
5 Suggested Answers
Touch2Heaven
  • 145 Answers
SOURCE: TROUBLESHOOTING ERROR CODE SC320
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
Posted on Jun 19, 2009
  • 8404 Answers
SOURCE: Ricoh Aficio 2018 ink rubs off paper too easily
Your corona wire is not function properly ... dirty or broken ... and/or the heater is not up to par.
Replace the corona and the heater roll to fix this problem.
Posted on Jun 22, 2010
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
SOURCE: RICOH Aficio copier is giving error code SC320,
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Posted on Jun 25, 2010
What is code sc320
SC320 is a Polygon Mirror Motor Error/Lock
Sep 14, 2010 | Ricoh Aficio 2022 Black and White Copier
RICOH Aficio copier is giving error code SC320, what is the problem?
Jun 14, 2010 | Ricoh Aficio 450 Copier
I have problem with Ricoh Aficio 1113, error code sc320
I am assuming you really meant an Aficio 1013 - SC320 indicates a polygonal mirror motor failure. This motor drives the mirror that distributes the laser to the drum. Could be a defective motor, poor connection between the motor and the BICU - one of the motherboards, damaged cable or defective BICU.
This will require a service call. Probably looking at an hour to diagnose the exact problem and an hour or two to repair plus parts. Could be as simple as a loose connector --- doubtful, but you never know.
Dec 24, 2009 | Ricoh Aficio 150 Copier
Sc320
That is a "Laser motor" Error - Laser motor is dead, and needs replacement
Aug 14, 2009 | Ricoh Aficio 180 Laser Printer
Cause:
defective
2.FCU defective
Clean & lubricate.
Jun 19, 2009 | Ricoh Aficio 150 Copier
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Apr 10, 2009 | Ricoh Aficio 1013F Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1018 photocopier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
199 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
