It sounds like a faulty or obstructed valve. How tough a job is it to fix? How do I order the replacement part if needed?
Model 110.92573210
Serial CE2170753
Thanks for your request, you do not specify exactly what the problem is, I am assuming it a problem with the filling cycle.
Turn off the water to the washer, remove hoses and check and clean the wire mesh filters in the valves, before reconnecting hoses, check the water pressure, reconnect and test, if you are still having a problem with it filling, then you may have to fit a new valve.
They are straight forward to fit.
To order a new valve, go on line to Kenmore washers.
I cannot give any more info as to where they are, as I am in the u/k, and we do not have Kenmore washers here.
Hope this helps you .
Plz rate my suggestions,and leave comment if need be.
Thanks.
