Question about Mintek MDP-1070
The screen goes black but if I close the lid and open it again the picture appears but the screen goes black again in a few seconds. The audio is fine
3 Suggested Answers
  • 1548 Answers
SOURCE: Player works fine with TV. Picture will not
If jiggling the lid switch causes the picture to show dimly, the switch may have bad contacts.
Can you see the picture if you shine a flashlight or lamp on it at an angle? If so, your problem is specifically the display backlight (including perhaps the lid switch in the circuit). If it uses Cold Cathode Fluorescent Lamps (CCFL), the CCFL tubes may be going bad, and jiggling the lid switch is having the same effect as multiple flips of a light switch to start up weak fluorescent light tubes. If the screen has a pinkish tinge or the light flickers a lot, that's another indicator that a bad tube is your problem. A replacement CCFL is probably about $8-$10, but the replacement requires some disassembly and highly skilled solder work (you have to make a physically small connection, and you can't have heat on it for more than three seconds at a time).
Posted on Jul 04, 2011
  • 34781 Answers
SOURCE: When I open the dvd lid, and I put the dvd in and close it, the screen still says its open and it wont do anything until the dvd lid is closed. Even though I close it, the player still thinks its open
There is a mechanical switch that is operated by the lid as it's closed. Sometimes, a DVD player such as yours can be made to work by pressing down on the lid but this is a sure indication that something is wrong with the switch. It isn't practical to hold the lid down for the entire time you're viewing a movie so repair or replacement is the only solution
Posted on Nov 17, 2012
Screen goes black close lid and open screen works fine
what configuration of the power manager do you use? laptop goes to hibernation mode automatically or by pressing the power button or by closing the lid?
Feb 04, 2014 | Dell Inspiron 1420 Laptop
Sleep mode
Reinstall the Power management . Install the updated graphics drivers
Aug 07, 2013 | HP Compaq Presario CQ60-249US Notebook
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
I have a Samsung R700 laptop . The problem is when the laptop is plugged into power lead it works fine but when it is running off the battery the screen flickers then goes black but comes back on after you...
Your LCD screen's picture comes from a very thin ribbon cable which has either a) worked itself loose or b) worn out, either way you will need to undo the four screws at the front of the screen (usually covered with 4 rubber covers). Very carefully unclip the plastic surrounds and then check for the connecting cable. If it needs to be replaced you can ussually locate one from Ebay.
Feb 23, 2011 | Computers & Internet
Screen turns off after a few seconds. Pressing the microswitch that closes when the lid is closed, brings the display back but it goes away after a few seconds again. I opened it up and tested the...
Micro switch is fine as its been tested so only reason that can be, lamp cover lid is not pressing that micro switch properly/ securely.
Please recheck lamp cover and make sure it is seated well on its location.
Aug 23, 2009 | Televison & Video
The screen on my Lattitude 120L won't come on after I close it
goto control panel click on DISPLAY then screensave then POWER SETTINGS and on the left side there is a section called what to do when i close my lid click on that and for lid settings click on do nothing so after u close ur lid it wont disable ur screen
email me at dragonslair2@hotmail.com
names mark
Jul 18, 2009 | Dell Latitude 120L Notebook
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
No picture
This is most likely your Backlight on its way out. Try looking closely at the screen to see if you can still see a dim picture if so then I am 100% sure that is the fault.
Dec 20, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Home dvd video player
in DVD mode, open drawer, remove disc, close drawer,
press "sub woofer" for 5 seconds
Jan 17, 2007 | RCA RTD160 System
Mintek MDP-1070 Logo
29 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
