Question about Jensen JER-422 Universal Remote Control
One of the too many remotes
I really want to scale down on my remotes. I have a JER422 [underneath is: 4531(BB)] I have a Memorex tv and a Phillips DVD/VCR combo. I don't have the faintest idea where the instructions and codes for the remote are and I need help getting everything set up. Any help would be wonderful
    Scholar:
  • 35 Answers
Well, I couldn't find a manual for your device (believe me I tried lol). The only thing I could tell you is that you will have to do a manual code search for your components. 1. Turn on the component 2. Press and hold the component key (TV, DVD, VCR-AUX, SAT-CBL) The illuminated on-off key turns on and stays on 3. While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off. 4. After holding down both keys for three seconds, the illuminated ON-OFF key turns back on. 5. Release both keys. The illuminated ON-OFF key remains on 6. Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks, and the next code in the list is sent. This process continues until all of the codes in the code lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON-OFF key blinks four times and turns off, all codes have been search. The manual code search method is exited.) 7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be saved. 8. To confirm that the component is programmed with the correct code for max functionality, test the component. Attempt to control a variety of the component's functions with the remote. Hope this helps. Good luck.
Posted on Jul 01, 2007
SOURCE:
How to auto program a phillips universal remote to a memorex blue ray player?
0483,0481,0488,0497 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 21, 2013 | Philips Phillips SRP1103/27 3-Device...
Need the code list for use of jr400 universal remote to a phillips tv
please send me a code for the dvd apex, i have a universal remote jensen jer422
Jan 14, 2010 | Jensen JER-422 Universal Remote Control
I have A MEMOREX TV I NEED A CODE FOR A PHILLIPS UNIVERSAL REMOTE
These are the codes listed in the 2009 Master code book
Memorex 0 1 5 4 ,0 2 5 0 ,0 4 6 3 ,0 1 5 0 ,0 1 7 8 ,0 1 7 9 ,
0 0 5 6 ,0 0 1 6
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Philips Magnavox Learning Universal Remote
I need the dtv remote code for my memorex dvd/cd player
I work for Memorex tech support. Our number is 800-919-3647.
Unfortunately, Memorex TVs and DVD players can not be controlled by universal or cable remotes. If you need a replacement remote, please call Memorex's parts distributor, Fox International at 800-321-6993 to make the purchase. If they no longer have stock, try www.remotes.com.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 09, 2009 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
Need codes for Sony Trinitron TV, with JER422 universal remote
Sony uses A LOT of their Codes over and over again. So I would say the free route is grab a Learning Remote (JER422) hopefully does it. Ask who has a Sony TV and Copy their Codes and test it on yours. Some or all will work it's trial and error, But Sony is pretty good with that repeat the Codes thing! Good Luck!
Apr 29, 2009 | Televison & Video
I need a remote
New universal remotes come with a code sheet that should cover most every brand TV ever made. I recently got a Phillips brand universal remote from Wal-Mart and set it up to operate a 15 year old JVC TV.
Nov 20, 2008 | Memorex MT1127 TV
42 INCH PHILLIPS LCD TV
you should take down the tv and and clean it. try and mix vinager and water together then wipe the tv down.
Oct 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Memorex television is not working with my new Phillips DVD/VCR combo
depending on how you hooked it up; if thru coax cable the you have to use channel 3 or 4 on the tv to use Philips. If you are connecting with video and audio cables then you have to select a/v input on tv to use.
May 08, 2008 | Memorex MT2271 27" TV
Input
u will need orginal tv remoteto change its inputs or logitch harmony ok
Feb 03, 2008 | Jensen 143307 Remote Control
Memorex MT2024 programing
THE ONLY SOLUTION IS TO ORDER A REMOTE FROM MEMOREX. I HAVE TRIED FOUR DIFFERENT UNIVERSAL REMOTES AND CONTACTED THE MFGS HELP-LINES WITH ZERO SUCCESS. I FINALLY GOT SOMEONE AT MEMOREX TO ADMIT THAT THEIR REMOTE IS THE ONLY ONE THAT WILL WORK ON THIS (MT2024) SET. "$88.OO".--- WHAT A DEAL FOR A NEW TV! IF YOU BREAK OR LOSE THE REMOTE, THE FRUSTRATION QUICKLY BUILDS AND ADDS UP TO MORE THAN $88.00
Sep 02, 2007 | Memorex MT2206 TV
Televison & Video Logo
57 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
