Question about Porter Cable Circular Saw Rip Guide 53125
I am trying to locate and purchase a porter cable #53125 rip guide but can't seem to locate one. Any ideas?
This is the guide specified in the owner's manual for my porter cable model 314 trim saw
5 Suggested Answers
muttandjeff
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
  • 1388 Answers
SOURCE: PIN100 leaves about a 1/8" of pin exposed every time.
I have seen many Porter Cable pin nailers with a bent or broken driver. Easy to check. With breakdown in hand (http://images.toolpartsdirect.com/schematics/portercable/pin100.big.pdf) remove head nut and other parts to gain access to piston/driver. (parts # 60084) Most drivers have the tip missing or driver is bent. Replace as needed. If driver looks good replace driver into cylinder and push all the way down. The driver should extend about 1/8" past nose. Check for obstruction around lower bumper. Parts are not expensice and are available at WWW.toolpartsdirect.com. Please email if you have any questions. Good luck.
Posted on Feb 16, 2009
Mentorcase
  • 5 Answers
SOURCE: Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Posted on Dec 08, 2009
  • 47 Answers
SOURCE: Only problem, I need an owners manual for Porter
Here ya go. Dewalt now owns Porter Cable and Delta so they have all of the manuals and parts diagrams on their servicenet site
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/A08202-E.pdf
Posted on Apr 07, 2010
Can you use 30 degree nails in a Porter Cable FC350 34 degree nailer?
Yes, you can use 30 degree clipped head nails in the Porter-Cable FC350 framing nailer. The FC350A and FC350B nailers are newer models that specify the 30-34 degree clipped head nails. Make sure that the nails are between 2' - 3 1/2" in length. The manuals for each of the later models do not explicitly list the 30 degree nails. Their specifications page do list the 30 degree nails. See http://www.portercable.com/Products/ProductDetail.aspx?ProductID=11542 and https://www.homedepot.com/p/Porter-Cable-3-1-2-in-30-Degree-to-34-Degree-Clipped-Head-Framing-Nailer-FC350B/203555581 . The manual for the FC350 is available here: https://www.manualslib.com/manual/132288/Porter-Cable-Fc350.html . It is the same as the manual for the FC350B, https://www.homedepot.com/catalog/pdfimages/7e/7e0d0f88-a9e7-4411-ad0f-7fc5c1c1fbaa.pdf .
I hope this helps.
Mar 21, 2018 | Porter Cable Air Tools & Compressors
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
I have a Porter-Cable model 724 Porta-a-band saw which is approximately 30-35 years old. It is leaking gear oil and the repair shop was unable to work on it. I would like to know where I can obtain an...
I found a breakdown for the model number 7724 if this is correct you can go to dewaltservicenet.com and download a parts schematic and also an owners manual for this tool. On the last page of the breakdown they list the grease used for this tool. If I have helped you would you please vote accordingly and thank you. If you need more assistance let me know.
Sep 09, 2011 | Porter Cable Saws
We purchased a Porter Cable Staple Gun, Model # DA250B. Unfortunetly, it does not explain how to load the staples into the gun! Could you please help us. Thank you, ...
Porter-Cable/Delta has an excellent support site, where you can find pdf manuals, part numbers, etc.
http://servicenet.deltaportercable.com/
Porter-Cable DA250B is an angled finish nailer- it drives 15 gauge brad nails, and won't work with staples. There are some smaller pneumatic tools that can drive both brads or staples, they are typically the smaller 18 gauge fasteners.
If you have the correct 15 gauge angled nails, the DA250B manual has nice pictures showing how to insert them.
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DA250B
Jul 16, 2011 | Garden
Porter cable air nailer leaking air from exhaust port continually
It certainly sounds like you may need to replace the seals on the tool.
The two main culprits are loose screws or bad seals.
Try tightening all the screws on the unit.
If that doesnt fix then you will need to purchase an overhaul kit for your model or take to a repair shop.
Since you did not give me your model #, Here is link to locate necessary parts:
Thanks
Apr 20, 2011 | Porter Cable Air Tools & Compressors
I need a switch for my Porter Cable Heavy Duty Belt sander model 361. PLEASE HELP ME LOCATE A SWITCH.
You didn't specify what type but I looked at a type 7 or so and the switch number is 697452 and list is 14.00. You should be able to buy that online or I would suggest if you have an electrical supply house in your area taking that one and matching it up, there is nothing special about it other than size, BUT make sure that they get one for the proper amp draw which is listed on switch. Let me know if I can help further
Feb 22, 2009 | Porter Cable 361 3" x 24" Belt Sander
Feb 16, 2009 | Porter Cable 23GA Pin Nailer Kit
Missing set of instructions for the porter cable template guide
Not having any luck with manual. All they say is you have to contact the service center for that. If you cant find anything let me know, I am in contact with a center at least once a week.
Jan 13, 2009 | Porter Cable-Cable 30mm Template Guide for...
Wobble in disk
if this is disk type grinder make sure you did not knock the disk out of alignment when it fell off table if so remove and re-align or replace disk seen it before make sure
Nov 24, 2008 | Porter Cable Porter-Cable Variable Speed...
How do I disassemble a porter cable 1002 router? I am trying to get to the motor in order to clean out pieces of broken brushes.
How do I hold the armature still on a Porter Cable Model 1002 Router to take the nut off to change the inner bearing
Oct 14, 2008 | Porter Cable Tools & Hardware - Others
Porter Cable Circular Saw Rip Guide 53125 Logo
81 people viewed this question
Top Porter Cable Saws Experts
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
