Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Leaking cystern The main seal (outlet)
  • bigslimaba May 11, 2010
    yes much more info
  • Bill Dickerson
    Bill Dickerson May 11, 2010
    I need more info
    Problem Solver:
  • 7 Answers
Go to to see if you have the right connectors for the main seal if so replace.
Posted on Feb 12, 2009
  • 547 Answers
Turn water off flush scoop out water remove 2 screws on side of toilet lift toilet off clean replace wax ring reinstall
I need to fix a drip or replace my cystern and the tap in the wall which is leaking. Terry Montgomery 0427183127
turn off the water at the mains where it enters the property
do both jobs then turn it back on there
May 25, 2017 | Washing Machines
I have just bought and installed the newbury close couple tiolet but when i flush it there is water leaking from the bottom of the cistern, but it only happens when i flush it any hlp would be great.
You need the proper wax ring to seal the toilet to the flange. Remove the toilet and check the wax ring. If it isn't compressed, get a spacer and a thicker ring.
Dec 05, 2014 | Home
Rear main seal for 1997 plymouth breeze
The leaking will continue or get worse until the seal is replaced
Jan 06, 2013 | Apex Digital Apex ABS100 - Rear Main Seal...
Coolent leaking around tube that inserts into the outflow water module(plastic) the other end of tube runs to plastic overflow container. what seals the tube into this plastic part??,,and why is it...
The entire outlet housing very commonly breaks and starts leaking. they even sell them at Oreilly's for around $20. There is a O Ring on the metal tube that seals it to the plastic outlet housing. It works very well to put Silicone sealer all over the end of the tube and push it inside this housing. Just let it sit for a half a day to dry before filling the anti freeze. Sometimes just replacing this O Ring will NOT seal it
Jul 03, 2011 | 2000 Chevrolet Cavalier
Need to remove lid on cystern
Hi im Rossouw
It depends on the kind of cystern u have. here is a few i know how to remove
1.The 2 button setting on top of cestern needs to be turned left untill it loosens up
2.The 2 screws at back of cystern lid needs to be unscrewd
3.also a 2 button cystern. has metel cabel under lid. can lift lid a littel. thast pull hard on cabel were it enters the 2 flush button meganisem
If not 1 of the above plz let me know and i will help u therder, dose are the most commen problem 1ns
plz vote 4 my advice thx
Jul 17, 2010 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
Replaced rear main seal on 5.7 but still seems to be leaking. Any suggestions?
Be sure it is the rear main seal,there is a cam plug that could be leaking,but if it is the rear main oil seal leaking,then I suggest removing it,and installing a rear main repair sleeve,this will give it a new surface to ride on,the crankshaft may have a groove cut into it from the oil seal,this will remedy the problem.If this was at all helpful,please rate,thank you.
Jul 10, 2010 | 1994 GMC Sierra
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
Engine main seals leaking
Replace them.
You will need to diagnose exactly which seals are leaking.
Replacing the front main seal requires removal of the cam timing components, including the timing belt and lower timing cog. The front main engine seal is installed in the oil pump, and can be removed with a pick. The new seal should be installed with care, using ether a seal installer tool or a socket/pipe of size equal to the metal ring in the seal, using a gentle tapping with a small hammer or board to ensure that you don't damage the seal. You must also ensure that the seal is seated fully in the bore. Ensure that you install the seal in the correct orientation.
If the rear main seal needs to be replaced, you will need to remove the engine or transmission from the vehicle to access it.
Dec 19, 2009 | 1989 Honda Civic
My Chevy 2002 Tahoe is leaking oil. They told me
this truck is equipped with an aluminum oil pan you could have 1 or several things going on... a stripped drain plug which is causing it to leak or it may be a leaking front seal or a rear main seal. If it is a front seal it is not to labor intensive. But if it is a rear main seal leaking it will require the transmission to be removed since the seal is a 1 piece rear main
Sep 07, 2009 | 2002 Chevrolet Tahoe
Kenmore Washer Water Leak
Pump is not repairable and yes your pump is shot. You can replace it farely easily and cheap at
May 22, 2009 | Washing Machines
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
267 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
