Size of HDD for Compaq Evo300 Desktop
What is the maximal size of HDD I can install in Compaq Evo300 Desktop? Thanks.
    Genius:
  • 1,019 Answers
HI,
This depends on what the Bios recognises.
And which Types of Drive IDE Or SATA.
Depending on the setup, and whats already in there, you could Go 80-100 Gig Comfortably. Or use an external hard-drive, if more space is required.
Mike @ compurepair.
Posted on Jan 21, 2009
Email pages in Yahoo are miimized size need to changed to maximized size.
You can't just change Yahoo, you must increase the font/text size for all web pages. This is done by selecting "My Computer" from the start menu and then from the next menu select "Appearance and Themes" and make the change to the text size.
Jan 20, 2012 | E-Machines eMachines Desktop PC
What's the maximum hard drive I can install in a Compaq SR1420NX I have a 80 hard drive right now I want to install a larger one. Will this computer handle a larger Hard Drive
The BIOS has a max. hard drive size limitation. Check the manual for the maximum size the motherboard can support.
If the maximum size hard disk it can support then you can add a second hard drive in the computer as a SLAVE hard drive to double your disk space capacity.
Mar 15, 2011 | HP Compaq Presario SR1420nx...
I am unable to install the network card of compaq evo... although i had tried to install driver from hp website of evo300 and evo500 series. please provide the solution for this issue.
There are 3 possible Ethernet adapters for your model.
3COM - Click For DownloadBroadcom - Click For DownloadIntel - Click For Download
Assuming you are using the card that came with the model and not a third party expansion card one of these three drivers should be the driver you require. Most commonly Broadcom is used by HP/Compaq systems so that is probably the best one to start with, Intel second, 3Com last.
Aug 27, 2010 | Compaq Evo D500 PC Desktop
Need to know what is maxim size hard drive can i install
You can install a hard disk possibly as big as you want, there are restrictions on RAM.
Apr 01, 2010 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
What is max size HDD for a Dimension 8400
As far as I know, there is no known maximum size. If you are making it a slave drive, you need to go into your system's BIOS and tell the computer you have a new HDD.
Restart your PC, and you will either need to hit your F2 key or Delete key repeatedly on boot. Just watch the top right corner of your monitor to know which button to hit.
Once you're in BIOS, just move to the hardware section or hard drive section and make the necessary changes.
Reboot and enjoy!
Feb 23, 2010 | Dell Dimension 8400 PC Desktop
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
What is the max HDD size for my Acer T135. Can I
yep - there is no maximum HDD size for computers just as long as you have the right connection (Sata or IDE) then you can fit any size you like.
Enjoy :D
Dec 03, 2009 | Acer Aspire T135 PC Desktop
Compaq armada e500
you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
Jun 02, 2009 | Compaq Armada E500 Notebook
Can i install windows xp on compaq presario 7360 . because it says memory size error
memory size error means that the computer doesent have enough physical memory to run windows xp,
Jan 04, 2009 | Compaq Presario 7360 (163874-003) PC...
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
Computers & Internet Logo
302 people viewed this question
David Payne
David Payne
