Question about MGE UPS Galaxy 3000 UPS System
MGE Galaxy 3000 UPS battery check needed
MGE Galaxy 3000 UPS is showing an alarm "battery check needed". Does this mean there is something wrong with the battery or is it a time based notification. If so, how can it be reset?
  • 21 Answers
This alarms indicates that the UPS has detected a lower than normal voltage, usually means that a battery is damaged at least. If the batteries are 4 or more years old... replace them all. If batteries are three years old or less, check every battery and replace the ona that you detect with a voltage lower than 13.0 vcd.
Posted on Nov 26, 2014
Alarm battery check needed ?
Posted on Apr 02, 2013
Hi How many batteries installed in mge galaxy 3000
Configurations vary, do you have a model number you can provide?
If you need any UPS help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website
www.psihq.com
Sep 17, 2013 | MGE Galaxy 3000 UPS System
Hello, our MGE GALAXY 3000 20kva, front panel display is frosen. UPS still operates but not able to use any buttons to see ups status. Also alarm states "internal communication fault". Would appreciate...
you need an MGE expert engineer to check on the internal components, maybe the display by itself it dead can be replaced while UPS is on no problem. if you want to switch off the UPS you go for force shutdown but I cannot guarantee will restart if you do not fix the fault.
Aug 09, 2013 | MGE Galaxy 3000 UPS System
I have a MGE Galaxy UPS and it's giving me an intermittent alarm saying "INV. NOT. SYNC./ AC.BP".
Dear Yared,
The alarm is pretty clear about what is going on. It's a syncing issue between the inverter and your bypass supply.
What you can try is to go to the 'Command Screen' of the UPS and select Resynchronize AC BP.
Best regards,
Ron
Nov 13, 2012 | MGE UPS Galaxy 3000 UPS System
MGE Galaxy 3000 UPS, do i require to reconfigure the ups after battery replacement? Thanks.
No you don't have to reconfigure the UPS after battery replacement. However you may have to reset the battery Timer. There are 4 possible ways.
1. Press and hold the fault reset button for 3-5 seconds
2. Press and hold the fault reset and security key simultaneously for 3-5 seconds
3. Press an dhold the fault and alarm silence buttons simultaneously for 3-5 seconds
4. Cycle the logic Power. This means to remove power from the main processor.
5. Call MGE. They have the software to reset the battery replacement alarm
Oct 19, 2011 | MGE Galaxy 3000 UPS System
I have mge galaxy 3000 single unit 30 kv who shown those messages: defaut refroidissemt defaut temp batterie thank you for you help
sounds like you have a battery in thermal runaway. That means your battery could catch fire. I don't know what refroidissemt is. Your spelling is wrong. Go back to the UPS and write down the right alarms. Then I can help you.
Sep 24, 2011 | MGE Galaxy 3000 UPS System
Galaxy 3000 30kVA not showns "battery charge"?
I can help you with this issue. Can you please give me some more information? What is the actual alarm saying? I know these UPS systems quite well
Sep 13, 2011 | MGE Galaxy 3000 UPS System
Hello I have a problem on MGE Calaxy 3000 20KVA UPS. I change the batteries with new batteries when i put it on, the battery status deos not come just give me xxx . before has this erorr "UPS...
The Galaxy 3000 uses a software which has all the data of the batteries used for the commissioning. However if the battery replaced are not of the same specification then the XXX would appear, meaning the software cannot match the specifications. Please try for first principle, check the ac in, check the rectifier and so on. Across the battery circuit breaker (in off position) compare the battery voltage and the charging voltage. This would give you an indication if the charger is working.
Apr 08, 2011 | MGE UPS Galaxy 3000 UPS System
Mge galaxy 3000 how to reset battery expire alarm after battery change
Unfortunately the reset is only possible with MGE software (Softunor).
Jan 24, 2011 | MGE UPS Galaxy 3000 UPS System
MGE Galaxy 3000 UPS shows charger internal fault .
mge galaxy 3000 battery circuit breaker shut off when normal power shut off too.plz help !!!!!!
Jul 29, 2008 | MGE Galaxy 3000 UPS System
UPS not charging
Sir, Our UPS is not charging at all. After following the procedure for shuting and starting up, it show battery charging 0%. The model is MGE Galaxy 3000 UPS and also cooling fan is going to falt mode .with best regards
Jul 02, 2008 | MGE Galaxy 3000 UPS System
MGE UPS Galaxy 3000 UPS System Logo
685 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
