Party waker battery not working
The unit will function fine with the AC power plugged in, but not at all if the AC power is unplugged
  • 3940 Answers
SOURCE: Battery won't charge
If the battery is not charging, then the charging circuit of the motherboard is bad.
Page 3-22 lists the spare part number for the motherboard. (4 versions depending on options)
Chapter 5 covers disassembly and reassembly
http://www.hp.com/ctg/Manual/c00212209.pdf
Posted on May 22, 2008
fossildude
  • 832 Answers
SOURCE: Dell 710M laptop won't work with battery
hi thanks for using fixya!
If your laptop is working exclusively on AC power and battery is seems to be useless, I suggest that you purchase a new battery for your laptop.
If you need further assistance, let me know
Posted on Apr 27, 2009
haayz
  • 197 Answers
SOURCE: i have a dell 1545 and when it is plugged in the
try to remove the battery first and plug in the ac power adaptor and see if it works. if yes, then your battery is faulty.
if it doesn't work i suspected that there's a problem with the power socket from your machine. you can check it with the nearest service center near you.
Posted on Jul 03, 2009
EMKartha
  • 163 Answers
SOURCE: Sony VAIO VGN-FE770G only runs on AC power, battery not working
This looks like the system is not able to sustain itself on the battery power. I have a doubt here. Is it a new or an old laptop. Either Case we have to suspect the battery charging and battery condition. One another reason could be that the battery contact is not good. But this could be of the least chance as the manufacturing of such devices would be perfect in all standards. Lets check the battery power first.
A sony Vaio never operates if the battery is not detected or the battery is not charging, while the system is up and running, you can see a small picture of the battery in the system tray which is at the right bottom corner of the screen. Run your mouse over the same and you will find a tooltiptext message and you can see if the battery is charging or not. If not, your hardware has a problem. If its charging but the battery charge is not increasing, then you have a battery problem. If its a battery problem and that the system is under warranty, you can well get a replacement for free. Hope this resolves the issue. Good Luck.
Posted on Mar 14, 2010
Testimonial: "Thank you for your help - I really appreciate it! My computer is 3 years old, so I suspect the battery is defective. "
RescueTechLA
  • 2653 Answers
SOURCE: Dell PP29L backlight turns off on external power
I'd try:
Updating the bios to the latest version
Uninstall video driver and check for newer version
Replace the inverter.
Let me know if any of those suggestions work, if not we can try something else.
Posted on Apr 03, 2010
Hp 2510p not charging
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery.
For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
hope this helps
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Oct 09, 2012 | HP Compaq 2510p Notebook PC
Msi wind u160 runs on mains power only
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
hope this helps
hope this helps
Oct 08, 2012 | MSI Wind U160-412US Black Intel Atom...
Error 305 in HP notebook
Third-party utility
hope this helps
Sep 25, 2012 | HP Computers & Internet
Toshiba l670d is not booting.
Third-party utility
hope this helps
Sep 22, 2012 | Toshiba Satellite L670DST2N01 Laptop
LG laptop battery
Third-party utility
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
Sep 06, 2012 | LG LB32111B, LB52113B, LB52113D,...
I have charged it and i still cant get it to turn on.
Third-party utility
hope this helps
Sep 05, 2012 | Computers & Internet
Enercell Laptop Battery Charger Doesn't Work When Plugged In?
Third-party utility
hope this helps
Sep 04, 2012 | Computers & Internet
Computer will not start up
Third-party utility
hope this helps
Aug 30, 2012 | Dell Inspiron 1501 Laptop
No battery is detected
Third-party utility
hope this helps
Aug 24, 2012 | Computers & Internet
What is the solution the battery is fine
Third-party utility
hope this helps
Aug 05, 2012 | Dell Latitude D510 Notebook
Computers & Internet Logo
393 people viewed this question
David Payne
David Payne
