Dell 8250 Hard drive 0 not found after move from US to UK
After my move to UK from US my Dell 8250 would not boot and gave me this messages - Primary hard disk drive 0 not found.  While trying to boot the hard drive made a clicking noise. I tried the system on 110 power via a transformer and directly linked to 240 power - switching the voltage input at the back of the computer.  Upon multiple boot attempts, I even got a software error message.  Any suggestions before I send to scrap!!!!!!
  • grahamdr Jan 23, 2009
    I bought the new drive today and have my original operating system and program cds.  I have an up-to-date external hard drive back-up so I've lost nothing except a few hours to load all my software.  Thanks for the input.
    Problem Solver:
  • 19 Answers
IT sounds like the hard drive went bad, especially with the clicking noise. If you want to keep the system, you will need to buy a new drive (relatively cheap) from tigerdirect or newegg and istall it. NOt sure if dell still send out recovery cds with their systems but if you have one just insert the cd after you install the new drive and follow the prompts. If you do not have one contact dell support and they should beable to send you one
Posted on Jan 23, 2009
Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Mar 09, 2010 | Dell Optiplex GX60 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Dell optiplex gx110 device detection problem
I'm guessing that the computer is not booting at all. This is saying that it cannot find any hard drive to talk to. Drives are labeled in the computer code with numbers starting at 0. There are up to 2 drives on an IDE ribbon cable, the Primary, and the "slave" or secondary. So, possibilities are that your hard drive died, the power connector to it came loose, or the power supply itself is having an issue with that connection that is attached to the hard drive.
Jun 11, 2009 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
May 14, 2009 | Dell (U0614) for Inspiron 5150 60 GB Hard...
Dell Dimension 8250 won't boot-up IDE fail code 5
install your OS and then firstly run chkdsk..
Jan 21, 2009 | Dell Dimension 8250 PC Desktop
Dell Dimension 8250
Yes you need a new hard drive
Dec 09, 2008 | Dell Dimension 8200 PC Desktop
D6000 DELL LAPTOP
Do you have any flash drives or external drives connected? If so unplug them and try to reboot. If not check to see if the hard drive is firmly in place sometimes they can come un hooked and that error will appear.
Oct 03, 2008 | Dell Latitude D600 Notebook
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Computers & Internet Logo
232 people viewed this question
David Payne
David Payne
