Question about Akai LCT3201AD 32 in. LCD Television
Tv is not turning on
Hello, I have AKAI TV model LCT3201AD. My problem is that I am not able to turn on TV with remote or manualy. Only if I unplugged the TV from the wall. Can u help me where is the problem? Thank you
  • Anonymous Jan 27, 2009
    I have a 37" combo TV/DVD unit. It's been doing this for about 6 months. Wrote to tech support from their website. Got nothing but an automatic response. When I called them, they automatically tell you the part you need is not available. It is a law that a part be available for 7 years. I have filed a complaint with the Bureau of Electronic and Appliance Repair (BEAR) against them. I need a new LCD control panel. Others have had success getting the parts they needed by going this route. Try it. Maybe they'll stop scamming us consumers. They get your TV back, fix it and resell it as reconditioned.
I had this same problem. I found a service tech in my area that knew the problem and the solution. Remove the back of the set and on the upper right side there is a black module with cooling fins on it. Amid the cooling fins there are 3 capacitors. They are black with a silver top, about 3/8" in diameter and 3/4" tall. The center of the top will be silver and will have two scored marks at right angles to each other. If the tops are swollen rather than flat they are bad and need to be replaced. Mine were rated at 16v 1000uF. He replaced them with 35v (maybe 36v I don't remember for sure) capacitors. They need to be unsoldered from the circuit board and new ones soldered in. Replace all 3. It only took him about 30 minutes to do and when if was fired up I found that not only was the problem solved but the picture and sound quality was greatly improved as well.
Posted on Feb 14, 2009
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3 > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
Jan 28, 2016 | Televison & Video
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
May 06, 2010 | Akai LCT2662 Television
(Please Help)Need to unplug my TV everytime to turn it on
you have a bad power supply, here is the part number
google it or try to get here :>
Fosg2000, Rate me Please
Mar 15, 2010 | Akai LCT4216 42 in. LCD Television
Tv stays in standby; won't turn on at the switch or with a remote
turn it totally and then turn it on with the controller them press the turn on button tis may just turn on the tv
Jan 26, 2010 | Akai LCT3201AD 32 in. LCD Television
I also have an AKAI LCT3201AD that keeps turning off.
Bad power supply circuit....
Bad resistors, rectifiers, capacitors, or MOSFET devices. Your tv needs to be serviced, and for this problem it should be to expensive and should be 'sameday return. Its an easy fix.
Jun 12, 2009 | Akai LCT3215/26 32 in. LCD Television
Need a stand and remote control for Akai LCT3201AD
Please check this Weblink as they might help you to provide desired parts for you Akai LCD TV.
Jul 27, 2008 | Akai LCT3201AD 32 in. LCD Television
Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Sep 09, 2007 | Akai LCT3201AD 32 in. LCD Television
See my other support issue regarding a simillar problem: Since this is a row of dead pixels and the TV is under warranty, you need to either contact the manufacturer or even exchange it at the retailer you purchased it from.
Jun 22, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
80 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
