Question about Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 gets no power
I just purchased a used xerox phaser 8400n & when I plug it into an outlet it doesn't power up. I've tried different outlets around my house & it still won't power on.
  • mmgthompson Jan 23, 2009
    TRied that to no avail. I did notice when I toggled the switch on a little green light through the metal screening would come on then go off. I'm not very technical at all, so I have no idea what that light coresponds to.
    President:
  • 2,072 Answers
I have been hesitating on answering this because people hang me out to dry on phaser printers when I give them good info. But here goes.
What you can try is go to the back of the machine, whre eh on off switch is located. there are 2 larger thumb screws you twist to align with the back frame. That holds the main board in place, Losten them, remove the main board, reseat the RAM memory into its slots, re insert the main board and try turning it on. If that doesn't work the most likely problem, ( 90 % likely) is the electronics module. And I am sure you did not pay as much for the machine as an electronics module would cost, Generally they are over $1000. Best price.
Posted on Jan 22, 2009
  • Rick Kasper Jan 23, 2009
    Bad electronics module.
Xerox Phaser 8400 prints pdfs in half page
I've seen this issue on some of my other Xerox machines (not the 8400 specifically). 9 times out of 10 the solution is to update both the printer driver to the newest version, as well as updating Adobe Reader to the newest version.
Here are the links to each:
Xerox Phaser Drivers
Adobe Reader
May 04, 2011 | Xerox Phaser 8400 Laser Printer
How to set up printer to print double sided. Printer Xerox Phaser 8400
First look at your printer identification.
You can see it in either the display or on the startup or configuration pages.
It must have a "D" in the name for you to be able to do automatic duplexing. i.e. 8400DN or 8400DX . Then you can scroll to printer setup
and select defaults, and then turn on the duplex, or double sided printing.
If yours does not have a "D" i.e. 8400, 8400N then you would need a new sim card to enable the duplex option.
Oct 22, 2009 | Xerox Phaser 8400 Laser Printer
37,002.47 in Xerox Phaser 8400
This is an electrical error in the printhead 650-4303-00. Unfortunately it is expensive.
Whit
Item, Inc.
Aug 10, 2009 | Xerox Phaser 8400N Thermal Printer
How do I remove ink from a Xerox Phaser 8400 - I want to load new ''fresh'' ink
I use a pen or something similar to work it up the loader and the stab it wit a push pin or paper clip to lift it out. You'll need to run some solid color pages to purge the ink from the printhead.
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Xerox 8400 Printer error code 37,002.47:181994
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
Could be a connector came unplugged. Could also be ink spill on circuit board, causing it to go haywire.
Jul 20, 2009 | Xerox Phaser 8400N Thermal Printer
Ink not being removed from metal drum, causing jam
Normally indicates that the mintenance kit is drying out and not properly lubricating the drum.
Or non xerox ink sticks have been known to cause that.
Jul 14, 2009 | Xerox Phaser 8400N Thermal Printer
Can anyone help I have a Xerox 8400N and im getting 10mm image printing down one side rest of page blank
About a 95 percent chance that you have a bad print head.You can try cleaningn cycles and also jet substuitution but your problem is blocked jets.
You could have a piece of paper between the drum and print head.
Dec 22, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
146 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
