Question about De'Longhi Nescafe Dolce Gusto Circolo Coffeemaker, Black
Flashing red and green button
I am pressing the on/off button to turn on coffee maker and it is flashing red and green intermittently, what is the problem please, i cannot find the manual?
Red Lite is flashing, unit will not turn on
if the red light is flashing this means theres a fault , most common fault on these are water catch bucket is full or not seated back correctly
Aug 24, 2015 | Amana D950EP Dehumidifier
Delonghi troubleshooting
Hi, my friend gave me a delonghi 5 cup k mix coffee maker. the water starts to heat you a hear a gurgle a little water is filtered to the pot and then nothing it just stops working. any ideas on how to trouble shoot?
Jan 02, 2014 | Dehumidifiers
Flashing green light stays on, unit won't start when you press the on/off button
I believe the unit needs to me reset to the manufacturer's default settings. To do this, turn the Master ON/OFF Switch to OFF and unplug the unit from the outlet for 10 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. The green light will blink until you change the humidity setting to below what the humidity level is in your home. If you set it higher, it will not turn ON or will turn ON only for a couple of minutes.
Also, check the position of the water collection bucket, to make sure that it's installed properly and has triggered the safety device.
To help you more, I have included a link to your Owners Manual that you can download and print for future reference, if you have misplaced yours. Take good care of your unit and perform routine maintenance regularly. As Danby has discontinued (retired) your model humidifier.
http://www.danby.ca/cms/uploads/products/en_manual/DDR4007EE2.pdf
Hope this helped you. Please let me know. Thanks.
May 06, 2011 | Danby DDR4007EE Dehumidifier
Programming timer
SETTING THE MACHINE TO TURN ON
1. Make sure the dehumidifier is plugged in but turned off.
2. Press the button with the clock symbol below it.
3. Press the up arrow to set how many hours until you want the machine to turn ON. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
4. After you have stopped pressing the arrow buttons the display will return to the original display showing temperature and relative humidity.
5. After the above steps are completed the dehumidifier will turn ON in the number of hours that you have set (programmed).
SETTING THE MACHINE TO TURN OFF
1. Make sure the dehumidifier is plugged in and running. You should hear the fan blowing for sure.
3. Press the up arrow to set how many hours until you want the machine to turn OFF. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
5. After the above steps are completed the dehumidifier will turn OFF in the number of hours that you have set (programmed).
Jun 21, 2010 | Danby DDR5009REE Dehumidifier
Keeps flashing bucket full and there is no water in the bucket.
water is not draining into the reservoir an thats why it keeps on blinking so clean out the drain assembly an treat with bleach ,,,,
May 24, 2010 | LG DH504E GoldStar Dehumidifier
We have LG65 model dh5018 that froze up and now doesnot want to work
if you carefully examin the compressor/motor, there should be a small red or orange button on the side of it. Or it may be inside the the terminal box.TURN OFF POWER BEFORE YOU START!!!
press the button in firmly and you shoul feel or hear a click.
That is the motor protection 'overload".
once pressed. close it all up and turn on power.
Feb 02, 2010 | LG Dehumidifiers
Newair ADS-300 Dehumidifier
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Red light comes on for no reason. Danby DDR6588EE dehumidifier
I have a DDR4588EE (same model with 45 pint capacity) and had the exact same problem. It's caused by the float at the top of the bucket being in poor contact with the "full" detector button. When the bucket is not full, the float on the bucket is supposed to press against the button. When the bucket fills, the float is supposed to push up off the button which causes the unit to stop and the red light comes on. The problem is that for some reason, the float isn't pressing hard enough against the button to push it properly in when the bucket isn't full. I fixed it by sticking a few little squares of duct tape (3 or 4 layers) on the float to make it press the button more firmly. Seems to be working fine now. Careful not to put too much tape or it might press too firmly which would result in the float not releasing the button when the bucket is full, and water will spill over.
Sep 17, 2008 | Dehumidifiers
Runs for a second
your problem might be with the switch itself. remove the back of the unit. on the lower right side is the switch. with the bucket in place and the unit turned on play with the red or black wire. there might be an intermittent problem. if so look in the manual for the parts breakdown. it will list the part number for the switch. not hard to change. first remove the bucket,then go to the red button and remove the button. behind the button is a nut which holds the switch in place. remove the nut and the switch will come off from the back-----good luck
Aug 20, 2006 | Kenmore 54351 Dehumidifier
Damby ddr451
Check your tank. Remove it and look to be sure that there isn't any shipping foam or foreign objects in the area which may be keeping the safety switch open. If the area is clear check the switch to make sure that it is not stuck and it moves freely. If that is OK replace the tank and make sure that it is installed completely and correctly. Try it again. If it still does not work I would take it back to the store and have them check it out under the warranty. Good luck.
Jun 29, 2006 | Danby DDR451 Dehumidifier
De'Longhi Nescafe Dolce Gusto Circolo Coffeemaker, Black Logo
144 people viewed this question
Top De'Longhi Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a De'Longhi Dehumidifier Expert? Answer questions, earn points and help others
