FixYa.com
Tags:
D-Link DCS-6620 Network Camera
DCS-6620 locks up and will not Pan and Tilt
posted by radius1 on Jul 01, 2007
I have a DCS-6620 that is about a year old. Lately I find that the camera locks up and refuses to move although it continues to otherwise function. I can not move the camera, zoom or focus the camera remotely. This usually happens on a windy day when the camera gets blown around a bit. I have it outdoors in the DCS-70 outdoor enclosure. Sometimes I can get it to reset itself by going into the web configuration menu under tools/default and selecting the button to recalibrate at the bottom. Even if it does not work immediately, the camera usually self corrects by the next day and the problem repeats itsself. The camers is remorte so it is difficult to try to do a physical reset. It would appear that the camera is loosing its location registration information. Any thoughts?
Comment by radius1, posted on May 01, 2008
Thanks, but the camera is hard wired. I realize now that the problem is with the software that can not handle the outdoor enviroment unless hard mounted to something that will not let it move in the wind. That makes it pretty much unuseful for my application where I have to mount it on a high pole.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 30, 2007
Thanks for Trying (70)
Silverdragon
Rank:Wiz Wiz
Rating: 82%, 705 votes
From wat ya say it seems to me that you are loosing ya signal sometimes? perhaps a "Better" antenna on the Base unit may help, one with a "High Gain" Also perhaps ya need to check and clean any connections etc. Hope that helps.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 13, 2007
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
dcs6620 is not wireless , thats the dcs6620G
Solution #3
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
To reset my DCS-6620 (mine is actually DCS-6620G), I find I have to unplug (disconnect) the 12V power from the camera itself. It is not sufficient simply to turn the mains power off.
Can you Help with these Web Cameras problems?
Web Cameras
driver forwebcam
i've lost my cd to install a... Answer This...
Web Cameras
mikomi web cam driver
got the above but no disc for... Answer This...
Windows internet explorer...
I can see the image and control... Answer This...
web cam
hello i want the web cam site... Answer This...
Air Card connection
I am using five D-Link cams... Answer This...
Repair Service
Find Web Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
