Question about Reddy Heater-170,000 BTU Kerosene Deluxe
I have a reddy 115k kero unit, i push the start button, it fires,
Blows some exhaust then shuts down. any guesses?
  • 92 Answers
Check for spark first, if you have good spark it is the flame sensor, you can get one that will fit from Mr. Heater. the wires are different but they all work the same, just splice it to your old wires. there is no wrong way to hook it up.
Posted on Jan 23, 2009
Does not ignite
alcy 04,
I'm just guessing but your unit tries to start, blows some fuel, then shuts down. This is a common problem with Reddy heaters. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which will solve your problem and get you the parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Reddy R155D Utility Heater
CAN I PUT DIESEL IN MY KERO REDDY HEATER 150,000 BTU HEATER AND WILL IT SMELL OR RUIN IT
since the combustion temp of diesel is different from KERO, expect the heater to shut down from overheating at times.
since it will probably heat up faster than on KERO.
Jan 31, 2010 | Reddy R60A Utility Heater
Will not ignite after replacing air filters
Clearly a problem with the new filter.
Does it have a check valve built in?
Try to get a flow through it without the nozzle attatched - and often there is a small sintered filter attatched behind the nozzle anyway. take off nozzle and try priming (without igniting obviously).
Could be air in there so needs priming. Often heaters shut down if air is present - so need to be bled of air. If you can pre-fill the filter, or bleed air at a joint just after the filter - this usually works.
Please rate at Fixya if this solves the problem. - It is free, and I improve my score if you do.
Thank you.
Feb 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 35,000 torpedo heater
unit needs photo cell,or cell is dirty.to check photo cell disconnect the two blue wires from reset switch nad put a wire between where the blue wires were connected.that takes the photo cell out of system.fire unit up.if it stays running photo cell is bad,change it and all will be right again
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Unit will not fire off when switch is turned on (kero unit)
Basicly I need the repair shops near Albany, Ga. I E-mailed reddy but have not heard from them
Jan 15, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heat/scheu kerosene space heater no ignition
Typical kero heater uses either a spark ignition or a hot surface. The hot surface igniter is very fragile. A small bump may break the elements. Flame is detected by a photocell, signal is sent to the lockout relay board. Change the igniter costs about 50 bucks.
Nov 29, 2007 | Scheu (K50-FA) Heater
Reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
Nov 02, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
107 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
