Question about SimpleTech 500GB SIMPLEDRIVE EXT HD-USB 2.0 7200 PININFARINA 500 GB Hard Drive
Necesito controlador para windows 7 del simpletech 500GB
Hoy compre Simpletech 500GB USB 2.0 y lo instale; pero Windows 7 no me lo reconoce. No lo incorpora al equipo y no se puede abrir. Con un controlador o drivers para win7 se soluciona. Favor mandarmelo a jemorgom@gmail.com o jemorgom@cantv.net. Gracias
IB4G2008
  • 3587 Answers
SOURCE: PC cant detect my Simpletech 500gb hard drive
well..you can 'see' it on the my computer, right? welll, then perhaps you'll check the usb cable, no?
Posted on Apr 03, 2008
  • 11 Answers
SOURCE: Drivers for simple 160gb
To access an external USB drive in Windows 98, you need to be using Windows 98 SE (Second Edition). Before SE, there was no USB support in Windows 98.
Even then, you will probably not be able to access the full 160Gb of the hard drive. Your best bet is to upgrade to a newer version of Windows, such as 2000, or XP. I know that, depending on your hardware, that might be asking a little too much, but to support all these more modern gadgets, you're going to have to give up on 98 eventually.
Hope this helps.
Posted on May 19, 2008
  • 8 Answers
SOURCE: Simpletech 250GB not working with my computer
This is the email I sent to & received back from the company re: the same problem I was having with it. You don't need any drivers.
PROBLEM: I have followed directions re: plugging device in, still cannot see device in MY COMPUTER. I have also tried plugging both USB's into computer to no avail. Even tried using it on my laptop, still not showing. My desktop is XP & loaptop is Vista. When I go to remove the dirve, it DOES show as Fujitsu, but I cannot acces the drive or locate it elsewhere. I really want to like this, but will have to return it if this issue is not resolvable.
SOLUTION: You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Regards,
SimpleTech Technical Support
Posted on Jun 05, 2008
Randy V
  • 236 Answers
SOURCE: SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
Posted on Aug 12, 2008
bizelski
  • 118 Answers
SOURCE: SIMPLETECH 160GB EXTERNAL HARD DRIVE
Is this compatible with vista?
Ensure all the plugs are right and try on a different pc to see if its the pcs or the exhdd's problem
Posted on Oct 11, 2008
Mi malibu maxx 2004 necesita un cambio de aceite cuando lo compre me dijeron qe el aceite que lleva es color azul pero me dicen que no existe ese color!
hola , tengo un carro malibu 2004 , y creo ke esta kemando aceite , hoy ke trate de prenderlo me encendio la luz del motor , le cheke el aceite y le asia falta , le puse , pero la luz no se le apaga y cuando le aselero tiembla cual podria ser el problema , me podrian guiar por favor
May 29, 2012 | 2004 Chevrolet Malibu Maxx
I had backed up my entire laptop onto my simpletech external hard drive, and then had to have my computer whiped clean. When this happened, I also installed a new version of windows (Vista to windows 7)....
Does the external drive work correctly when connected to any other computer?
If not, then it has "died".
It might be possible to open the SimpleDrive case, extract the disk-drive,
and connect it as a "slave" disk-drive in some computer, to see if the "bare" disk-drive can be read.
Aug 19, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Hola, tengo un controlador behringer BCD 2000 y mi portatil es de windows 7, el problema es ke los driver del controlador no estan actualizados (hechos para XP) y por lo tanto no puedo hacer funcionar...
Hola, pruebe este enlace http://www.driverscape.com/download/Behringer-BCD2000-v1.0.0.6 detecta su sistema operativo para darle el controlador correcto para su ordenador. No entiendo el espa?ol. ยก sin embargo, he traducido al ingl?s!
Jul 22, 2017 | Computers & Internet
He formateao mi portatil sin hacer antes copia de seguridad de los drivers, ahora me falta controladora de bus sm, controladora ethernet y pci device, no me puedo conectar a internet porque no reconoce la...
Ir a la >>>> drivers at softpedia dot com >>> y descargar los controladores para
Acer Aspire 5610 LAN Driver 9.25.0.0
Estos son los controladores que necesita para obtener en Internet, pero hay que ponerlos en una USB o un CD para instalar. Una vez en la Internet, puede obtener el resto de su l?nea de controladores. Descargar un programa llamado Speccy, de Piriform dot com. Se le dir? exactamente lo que usted tiene equipo para obtener los controladores para. Buena suerte a mi amigo.
Dec 09, 2010 | Acer Aspire 5610 Notebook
Necesito una controladora ethernet porfa ayudenme con ello plis
vaya al sitio web y el clic Pasa debajo del título "Sitúa 1", descarga el archivo, abre cremallera el archivo y entonces lo corre, instalará al conductor para usted. arrepentido tomó tan mucho tiempo
http://www.realtek.com.tw/Downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=7&Level=5&Conn=4&DownTypeID=3&GetDown=false
May 07, 2009 | Computers & Internet
Controladores para windows xp
Yo tengo los controladores, pero los puedes buscar en la pagina de rapidshare. yo los descarge de ahi y me funcionan correctamente.
mi correo alsace2407@yahoo.com
May 05, 2009 | Computers & Internet
SimpleTech 500GB SIMPLEDRIVE EXT HD-USB 2.0 7200 PININFARINA 500 GB Hard Drive Logo
65 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
