Question about Magic Chef Refrigerators
Magic Chef CTB1723AR Top Freezer 16.8 cu .f
The compresor starts too often...(i think loussing the in side temperature ) Thank you !
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
SOURCE: Magic Chef MCWC30MCG not getting cold?
You need to replace the Ptc unit attached to the compressor. Go to REPAIR CLINIC.COM and order the following part. 1206838 Ptc relay. They also will show you were it is located and how to replace it. Compressor tanks very rarely go bad. It is an $11.00 dollar part
Posted on Jan 30, 2009
  • 4 Answers
SOURCE: Magic Chef MCWC30MCG not getting cold anymore?
Replace PTC Starter and that is it. You can also try to open and clean contacts, I did and it worked.
Posted on Mar 30, 2009
Todd_pdx
  • 22 Answers
SOURCE: Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Posted on Apr 06, 2009
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
A/C unit no longer cooling. Showing pressure at 100 psi.
did you use a manifold gauge, HI and LO side, if your compresor is not engaging probably due to a low charge, because your gages must read about 15F below ambient temperature that translate to on a 80f day uyour gage must read about 95psi on hi and lo (no compresor running)with compressor runing your lo side must be around 35psi and your hi side around 200+ psi depending on amount of air cooling your conderser, also note charging amout tag to not overcharge system, on other hand your problem may be a electricall, check your fuses and MG/C cluth relay by pass it to confirm your compresor is in good working condition.
Jul 08, 2012 | 2000 Toyota Celica
My refrigerator LG GM 313SC wasn't working yesterday, I disconnect the refrigerator and notice that the compresor was too hot, I reconnet the refrigerator at night and in the morning checked the compresor...
I have 2 of the LG GM 313SC. Purchased brand new here in the Caribbean (Dominica) Both units when I turned them on for the first time are making a 'clicking' noise that is happening together with blinking lights on the temperature control inside the fridge section.
It isn"t even turning on. The light inside is dim, which the manual says is an indication of a problem, and to call an electrician. I think not, they are brand new and behaving the same way.
Any suggestions
Oct 21, 2010 | LG Refrigerators
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Side by side Profile refrigerator,compresor run all the time temperature is 50 for fridge 16 for frezer????
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 | Freezers
Refrigerator won't get cold
y have a problem don't speach engleash but my refrigerator model side by side frdrs21dcms have a problem congelator is ok but refrigerator not dawn a temperature and compresor running
Apr 18, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Refrigerator continuously cycles
This is a generic problem with Whirpool refrigerators.The start relay for the compresor(located on the side of the compresor under the black plastic cover) is probably bad ,replace it(about $ 20) with a new one(write down where the wires go) that should solve the problem if not the compresor is bad.
Apr 15, 2009 | Whirlpool Refrigerators
Not getting cold, condenser dosn't sound like it's working, I hear a clicking sound like a relay but nothing turns on after the sound
If you hear a clicking sound,probably is the compresor trying to start ,if the condenser fan motor work ,first replace the relay wich is not expensive ,if it doesn't work you have a bad compresor.
Apr 10, 2009 | Refrigerators
Turns on...clicks every few minutes....never gets cold
It looks like the compresor is trying to start and goes off on overload ,it could be a bad relay or a bad compresor.Try first replacing the relay located on the side of the compresor under a black plastic cover(ALWAYS UNPLUGGED THE FRIDGE BEFORE DO ANY WORK) if that does not work you need to replace the compresor.
Apr 09, 2009 | Danby DAR482BLS Compact Refrigerator
Refrigerators Logo
95 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
