Grundig misuro HD tv dvd combo won't read dvd
  • 2318 Answers
SOURCE: HD ready?
Your TV will be able to pick up the OTA channels by installing an outdoor antenna. After installing the antenna you will need to do a channel scan.
It is hdtv compatible, no need for a converter box but if you have cable TV or satellite, you still need to subscribe for the HD channels.
Hope this helps.
Posted on Jan 17, 2009
RNS-Systems
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Posted on Oct 16, 2009
  • 43 Answers
SOURCE: help, we have a dvd
Look for a little pin hole next to the dvd slot. If there is one, try using a paper clip to push the manual eject lever on the inside.
Posted on Mar 27, 2011
bugoy31
  • 1238 Answers
SOURCE: DVD on Curtis LD DVD
Good day!
may i know if your unit is under warranty if yes I suggest to don't open it because it void your warranty.
Or Try to used a CD lens to clean the DVD lens inside.
If the problem persist just add a comment.
Thank you
Posted on May 25, 2011
SOURCE: I have an LCD/ DVD
then there is a problem with your cd case .........................................................
ON THE BACK OF DVD THERE IS A WIRE OR SUM PIECE PULLED IT BY USING SOM CLIP THEN THE DVD'S DOOR OPEN EASILY..........
Posted on Aug 07, 2011
PSE ADVISE HOW WE GET DVDS OUT,THEY GET STUCK IN THE TV UNIT ? IS THERE A SAFE WAY TO GET IT OUT ??? THANKS FOR ANY HELP U CAN OFFER, WE LUV OUR GRUNDIG THAT OUR DAD LEFT TO US. ITS A MISURO HD UNIT.
Check near the DVD opening for a small pin sized hole if your lucky it will have one of it does then grab a small paper clip unbend it so it's strait insert in pin hole and put some pressure behind it hope this helps
Nov 22, 2016 | Grundig Televison & Video
Need code for Grundig misuro hd Tv/DVD
2409,2448. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 26, 2015 | Televison & Video
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
RCA L32WD26D TV/DVD/HD Combo - dvd wont eject
Hello
Check the loading motor and loading belt. If loading motor has damaged, or loding belt has broken or loose. the in-out tray mechanism won't work well.
Mar 03, 2012 | RCA L32WD26D HDTV/DVD Combo
I have an LCD/ DVD combo and the DVD won't come out. The tv still reads the DVD but won't eject it. I've tried on the remote and the unit :(
Aug 07, 2011 | Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
