Question about 4103LX 4Button Remote Start System with Keyless Entry
I mistakenly tried to remote start my car when the key was in the ignition and since then the remote start stopped working, doors/trunk lock/unlock works fine
Remote start worked well untill I tried to remote start with the key iin the ignition, in the documentation it says DO NOT TRY TO REMOTE START WHEN THE KEY IS IN THE IGNITION
    New Friend:
    Problem Solver:
  • 5 Answers
Best thing i would do is remove the battery for a few minutes and then put it back on
Posted on Jan 09, 2013
  • mehdi_bond
    mehdi_bond Jan 09, 2013
    Which battery you are talking about the car battery ? This won't make the system loose all the configurations ?!
  • mehdi_bond
    mehdi_bond Jan 13, 2013
    The issue was , I accidentally switched the button that disable the remote control, I did not know its location and have hit it with my foot. The problem was resolved but switching it back on.
4 Suggested Answers
  • 1796 Answers
SOURCE: car keeps grinding when start
Hi!!
Relays are activated when they receive a Positive (+) or Ground (-) Signal depending on the system design, in the case of the Starter Relay, the signal comes from the Ignition Switch when turned to the START position. The remote starter also sends the same signal to the Relay to activate the Starter and CUTS it OFF when the Remote Starter Module receives the signal that the engine is running. In this case, the Relay signal does not CUT OFF and keeps sending the signal to the Starter, usually this signal is send by a Relay integrated and controlled by the Remote Starter Module. I believe this relay is defective and getting sticky, reason why the Starter keeps running after engine starts. I suggest to take vehicle to an Alarm Shop and let them fix your problem.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Jan 05, 2011
slick42371
  • 42 Answers
SOURCE: I have a highlander 2005 and had a Avital remote
It sounds like the tech who installed this in your truck doesn't know what he is doing. I have been a tech for 20 years and have done 100's of these trucks for keyless remote starts. The door lock wires are in the drivers door or behind the glove box. There is some time in doing this because you have to build relays and use diodes for them to work, but it is possible to be done.I would find another place to do it and bill the first place that could not do it.
Posted on Feb 02, 2011
  • 1833 Answers
SOURCE: After starting vehicle with remote
According to your problem you can first change your remote battery to if it is not malfunctioned for battery. Before start the vehicle press lock key for 1 second to lock the door from remote. If the door locks are connected then horn will honk and the parking light will flash once. If the system is armed then status Led will flash once per second. After check it you can start your vehicle. But don't remote start your vehicle when the key is in ignition. It may help you to solve your problem.
To know more you can follow the manual.
Posted on Mar 16, 2011
1999 Jetta GLS - Key buttons stopped working - no longer could lock/unlock doors remotely. Using key manually worked for a while. Now key can be inserted into driver door (only exterior door lock) but...
Have you replaced the battery lately? If so , you could have a bad battery in your key. It is a small microchip in some cares and will effect unlocking and starting the car if the battery is weak or dead.
Jul 31, 2012 | Volkswagen Jetta Cars & Trucks
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
The remote to unlock the doors won't work. replaced battery. the key will not unlock driver or passenger door or the trunk
I hope you're able to get into your car because it sounds like the system needs to be reprogrammed.
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice this is rewrite mode,have all remotes to reprogram it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
Aug 11, 2009 | 2005 Toyota Corolla
Door locks wont work
check if the batteries in key remote are good.
if good
nedd to reset your key by putting in the ignition just turn the dash lights on ...dont start the car and once the ignition lights shows on the dash board just press unlock and lock once ot twice until it locks and unlocks while u in the car. try that it had worked for me before should do for urs.
May 12, 2009 | BMW X5 Series Cars & Trucks
1999 VW Jetta GLS - Key and door lock malfunction - Locked out
Needs new drivers door lock actuator (P/N 3B1-837-015-AS)
Aug 26, 2017 | 1999 Volkswagen Jetta
Security system locked down on 2003 CL55AMG
hello,try to check your battery in your remote key or use your spare key,then try lock and unlock your car,maybe 3 to 4 times until it"s work,ty
Apr 24, 2009 | Mercedes Benz Travel Alarm Clock
Remote locks the doors but will not unlock doors or trunk Battery
It is entirely possible that the unlock button on the remote is worn such that it is not making contact. I've seen this happen many times, as the unlock button is pressed so much more than lock. You might try to reprogram the remote first before you look into getting a new remote. The procedure goes like this. Close and lock all doors Key in and out of the ignition 6 times, hazard lights should flash twice Turn key into accessory or on position Unlock and lock doors with drivers switch Press lock or unlock on remote Hazards should flash again to verify recognition turn key off  manually unlock door and then open and shut it.  you should then be able to test remote.
The key to the procedure is doing step two quickly Hope this helps, if not you may need another remote or see dealer.
Apr 11, 2009 | 2004 Infiniti I35
Recode a key 4 bmw 318i cenral locking
To carry out this procedure you need to have one working key and one key which requires programming. It may help sometimes to hold the key close to the rear view mirror as this is where the sensor is located in most models. 1. With both keys, get in the car and close all windows and doors. 2. Put working key into the ignition and turn to position 1 (the accessories should turn on) (try also position 2) 3. Turn the key back to position 0 and take the key out of the ignition. 4. Using the working key, hold down the unlock button, press the BMW logo (lock button) 3 times, and release the unlock button. Doors should lock and unlock. 5. With the new key, hold down the unlock button and press the BMW logo (lock button) 3 times and let go of the unlock button. Doors should lock and unlock and you're done!! If not working try the following PREPARATION 1. Close all doors, trunk, hood and sunroof. 2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot. ENTER CODE LEARNING MODE 3. Open trunk and leave it opened. 4. Open the drivers door and sit in the drivers seat. 5. Close the drivers door. 6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated. ?Do No start the engine.? The Ignition switch cycling in step #6 must be performed within 10 seconds. The sequence in steps #1-#6 must be performed within 45 seconds. REGISTER/DELETE ID CODE(S) 7. Open drivers door, (remain seated in the drivers seat) 8. Close the drivers door. 9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered. 10. Repeat steps 7 thru 9 to register the three ID codes. It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory. EXITING CODE - LEARNING MODE: 11. Open drivers door, and exit from the vehicle, leaving the door opened. 12. Close trunk. 13. Close drivers door. The LED will turn off and the siren will 'chirp twice. 14. The initialization procedure is now completed; Test all remotes to confirm operation. If this doent work your alarm/central lock needs to be reset
Mar 28, 2009 | 1996 BMW 318
The Lexus car remote key control model ES300
try this:
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (DO NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
Mar 23, 2009 | 1997 Lexus ES 300
Lincoln Continental2000-Door key won't unlock door-but starts car
I locked the 2000 lincoln continental with the key fob but lost it now the ignition key wilolo not unlock the door
Jan 01, 2009 | 1999 Lincoln Continental
4103LX 4Button Remote Start System with Keyless Entry Logo
339 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
