Question about LG WM-0532HW Front Load Washer
How do I replace the front door gasket on LG WM0532HW
Gasket is torn and leaks and needs to be replaced
SOURCE: lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Posted on Jan 08, 2008
  • 132 Answers
SOURCE: Rubber Gasket Torn
IT IS EASY :
1- IF YOU SUCCEED TO TAKE OLD gasket YOU CAN DO IT FOR THE NEW ONE
2- IT IS JUST A RUBER PEICE SO YOU CAN
3- LIKE YOU SAID a {spring securing OR CLAMP } USING A SMALL TOOL {SCREWDRIVER OR BLAYER } TO DISCONNECT THIS SECURING PIECE IN FRONT THEN
4- FLAP THE RUBBER TO INSIDE THE DRUM THEN
5- THERE IS ANOTHER SECURING PIECE HOLD THIS RUBBER WITH DRUM INSERT YOUR TOOL AND DISENGAGE THEN
6- NOTICE THE TRIANGLE IN THE RUBBER PIECE
IT IS THE MARK TO CONNECT AGAIN IN RIGHT WAY OR YOU CAN MARK BY A PEN
7- REVERS THE MANAR
YOU WILL REACH
GOOD JOB
Posted on Jun 18, 2009
SOURCE: How to replace door gasket on LG WM0642HW Washer?
I also had a door gasket tear that caused water to spit out all over the floor so I had to replace it. It's a fairly simple job in theory, you can even find LG repair manuals online. The front panel comes off easy and removing the spring and wire clamps from the gasket is fairly simple. Getting the gasket back on is a different story. Seating the gasket is a bit tricky but I found that some lubrication helped greatly. Don't use oil based lube though because it could soften the gasket. I opted for a water based lube in the form of KY jelly (***insert crude joke here***) The drum side wire clamp was a bit of a challenge. My model had a hook on one end of the wire so that it came apart when removed. I think this made it much easier. Some models don't have the hook so you would need a tool that could stretch the spring. Something like a reverse pliers. Even with the hook, it was tricky. I found that jamming something around the gasket to hold the wire in place was helpful. I ended up using some vice-grips and needle nose pliers and all the strength I had to get it hooked. In fact, to sum up, the secret is to get enough force to stretch the spring. Once you figure out how to do that it's easy.
Posted on Oct 04, 2009
  • 6 Answers
SOURCE: How do I replace my door boot seal/door gasket on
There are 2 springs attaching the door boot. The springs are really tough but there are 2 separat tools for each spring. Use the tools to remove & install. It's tough but can be done.
Posted on Nov 10, 2009
SOURCE: LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Posted on Dec 19, 2009
It leaks from the door how do i fix it? and is it expensive to fix?
The door gasket is most likely torn causing the leak. It costs about $110 plus labor if you are not handy enough to do the replacement. Indicate the exact model number of the washer for the exact replacement part number and detailed procedure on how to replace the door gasket.
Jun 08, 2010 | Maytag EPIC MFW9700S Front Load Washer
Torn door gasket / collar
It requires technical expertise and speccial tools. Part isn't expensive, labor may be depending upon where you live
May 05, 2010 | LG WD-14124RD Front Load Washer / Dryer
My LG front loading washer is leaking at the door.
carefully check gray door gasket fot tears/waves/stretching on outer edge. if so, replace gasket. be sure gasket and door glass are clean where surfaces meet.
Apr 28, 2010 | LG WM2688H Front Load Washer
Lg lds5811 leaking in front at bottom left of door. cleaned gasket and door, still leaking. any ideas, thanks
if its leaking down the vent out the bottom of the door when it runs.you need to replace the vent fan ***.the gasket on the vent door is bad.
Feb 24, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Gasket is leaking
something has probably been left in a pocket and torn the front gasket or door boot as it is called. this will need to be replaced. it is not an easy job as the boot is held on by a large round spring.
Oct 11, 2009 | Whirlpool GHW9150 Duet Washer
My front loading Kenmore H2 has a torn gasket.
You will have to take the door apart to get the gasket mounted properly. Although not required, a second pair of hands really helps.
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2032HW gasket replacement
I have changed these without disassembling the unit. Just remove the spring from the gasket, then peel back the gasket to remove the inner spring. This is the easy part, getting the inner spring back on is a pain in the neck, but it can be done. The spring will give you problems either way. Good Luck
Aug 14, 2008 | LG WM1814CW Front Load Washer
Lg wm0532hw front load washer
Dec 12, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
48 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
