Question about VeriFone PCCharge Pro Full Version for PC
PCcharge overflow error
Getting an overflow error message
2 Suggested Answers
  • 19 Answers
SOURCE: pccharge invalid trout id number
It sounds like your TroutD has somehow gotten out of synch with the last processed transactions. Usually, you can go to setup -> numbers and synchronize the TroutD to the last number used. This will usually correct the issue.
Posted on Sep 27, 2009
INV MERCH ID 328
Hi 328,
If you are still using pcCharge, nothing in RPE/CRE changes. Your new merchant info goes into the pcCharge setup software. Let me know if this helps.
sysadmin@ccybernet.com
Feel free to email me with more details if need be.
Nov 20, 2013 | Pc America Restaurant Pro Express
Runtime error 94 in pccharge
I just had this same problem, I managed to fix it by starting PCCharge and typed in "SYSTEM" for the user and then clicked the password box and selected "forgot my password" it should prompt you for a security question, and then it let me log on without issue. After 7 years of dealing with PCCharge I can honestly say it is **** and if you have any choice switch to another payment software. If not, best of luck and I hope your experience is better than mine. CHEERS!
Oct 11, 2012 | Go Software Inc. PCCharge Pro...
When i try and open pccharge i get a invaled null and when i hit ok it closes out what can i do to fix it?
Invalid null refers to a database issue with the one of the fields in the database, or that one of the files being loaded when PCCharge starts. I'm guessing that you are probably getting an error 91 before comes up, then an "invalid use of null". Typically this indicative of windows not being up to date. The best solution for this would be to download the latest Microsoft Runtime Library.
This can be found by going to microsoft.com and searching for the phrase 'windows script'.
What this does is updates your system so that the newest components can "talk" to the database and the file that are being loaded when PCCharge runs.
May 20, 2011 | Go Software Inc. PCCharge Pro...
Hello I use verifone PCCharge, when I turn it on , an error message pops : "Password backup update failed.Shutting down PCCharge payment server"
PCCharge uses Access database, which is stored in .mdb file. Locate this file. Mine was in C:\Program Files\PCCW\PCCW.mdb.
- Back up this file.
- In the same folder where you found the database, there should be a program called VISDATA.exe. Double click on it to start it.
- Go to File > Repair Database, and point it to your database file (pccw.mdb).
- It will ask you if you want to open db, say no.
- Go to File > Compact Database, and point it to your database file.
- It will ask you if you want to compact to 2.0 or 7.0. I was told to use 2.0.
- It will ask you if you want to replace database, say yes.
- For encrypt, choose No.
- For open, say No.
- Close VISDATA.exe
- Try running PC Charge now.
- If it still gives you trouble, and if you don't mind losing all your history, move the pccw.mdb file out of PC Charge folder (C:\Program Files\PCCW\). Keep it somewhere else for backup, just get it out of PC Charge folder. Now, start PC Charge again. A new database will be created.
Mar 16, 2011 | Computers & Internet
PC CHARGE - "INVALID EXP. DATE" ERROR MESSAGE ON 2013 & LATER
when you have PC Charge open, go to Setup and Preferences. A window will open. In the "maximum/latest year" or something like that, change 2012 to something later like 2016. That should fix it
Apr 15, 2010 | Go Software Inc. PCCharge Payment Server...
Error 3343 when I start PC Charge, how can I fix this?
error 3343 is a database error. Unfortunately, PCCharge is still in the stone-ages of computer technology and they think VB6.0 and MS Access 2.0 are stable and secure ... At any rate. 3343 is simply an unrecognizable database, in this case due to corruption. There is a program in the PCCharge directory called VisData. This will allow you to run a repair and compact the database. To use:
First make a backup of your PCCW.MDB database in your PCCharge directory (C:\Program Files\Active-Charge (PaymentServer); C:\Program
Files\PCCW (PRO)).
Execute VISDATA.exe.
File -> Repair MDB.
Select the PCCW.MDB database from your PCCharge directory.
Select 'No" to open Repaired Database.
File -> Compact MDB ... 2.0 MDB
Again, Select the PCCW.MDB
It will then prompt for what you want the database to be named. Simply select PCCW.MDB again, select 'YES' to replace existing database.
Select 'NO' to encrypt database.
Select 'NO' to Open Compacted database
Exit Visdata and start PCCharge.
It would also be a good idea to go ahead and update to the latest available Scripting Runtime library. This can be found by going to microsoft.com and searching for the phrase 'windows script'. (To my knowledge, 5.7 is the latest version).
Jul 16, 2009 | Go Software Inc. PCCharge Pro...
Pccharge invalid trout id number
Jul 03, 2009 | VeriFone PCCharge Pro Full Version for PC
Phantom Transactions on PCCharge
One it is most likely you are getting communications errors while Pc Charge is dialing out which I am assuming you are using DIAL up.
You need to upgrade to Version 5.7.1 or above and then use dial or highspeed connection.
When the software dials out to the bank for approval while that process is going on your communication drops and then PC Charge will have no way of recording the Approval back. So in turn you are running it again where the approval for the first sal e was already done but the response was not captured. Your bank can put duplicate trans stops on the front end. Make sure you upgrade to the newest version.
www.greenlightpayments.com
Jun 02, 2009 | Go Software Inc. PCCharge Payment Server...
Error 232*
Error 232 Severity 16
Error message text Arithmetic overflow error for type %s, value = %f.
Explanation This error occurs when Adaptive Server detects an arithmetic overflow error during execution of a SQL statement. Arithmetic overflows occur when a variable has too few places to store the converted data. In particular, Error 232 is raised when an overflow occurs for a variable of datatype float.
Error 232 can occur during execution of the convert function. It can also occur during implicit conversion within Adaptive Server, either during a stored procedure run or during execution of a SQL statement which converts a float value to some other datatype.
Action Determine which variable is causing the problem based on the datatype reported in the error message output and the SQL statement on which the error occurred. If the error occurs within a stored procedure, an additional error message will be displayed showing the name of the stored procedure and the line number where the error occurred.
Increase the size of the variable that is causing the error. If it is in a procedure, re-create the procedure.
If this error occurs on a Sybase-supplied system stored procedure, contact Sybase Technical Support.
Versions in which this error is raised
Jul 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
I want to make a payment on my bill, don't know how to access that area on this website
PCCharge does not charge a monthly bill for use of it's software. Perhaps you should get in touch with your MSP. The only bill PCCharge would charge is either for the purchase of the software, or for the tech support contract (which is quickly becoming less and less worth the money). In both cases, you would need to contact their sales department directly.
Jul 02, 2008 | Go Software Inc. PCCharge Payment Server...
VeriFone PCCharge Pro Full Version  for PC Logo
48 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
