Question about Echo Garden
Echo SRM2010 What is the engine size on this machine ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
21.2 cc
Posted on Jan 16, 2013
Why won't my echo 230 start, has good spark.
If you have been running Ethanol (regular gasoline) in the gas+oil mix, your problem sounds pretty common. I suspect your trimmer is a year old or more and probably not heavily used. I had the same problem after a year. Took it to a professional and they told me the carburetor was shot. Home Depot sells the Echo and they do not repair the machine. What happens is the ethanol in the gas attracts moisture, which shortens the life of these 2 cycle engines. New carburetor, $139.00 +labor. New decent trimmer, $139.00.
Aug 17, 2014 | Echo Garden
2003 Toyota Echo will not communicate with inspection machine
I know why. Toyota issued a technical service bulletin (TSB) dated September 8, 2003 applicable to all models, including yours. The bulletin specifies removal of the original DLC3 (OBDII connector cable) and installation of a controller area network (CAN) interface module. You may have to take your ECHO to a Toyota dealer to accomplish this.
Mar 21, 2014 | 2003 Toyota ECHO
Spark plug gap size for 02 toyota echo
Spark plug gap size for 02 toyota echo?
NGK BKR5EY Spark Plug Gap: .031 inches or .8mm
Feb 08, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
Size file sharpen poulan 18
Take your saw to a shop that repairs chainsaws. They will be able to get you the right file for the size of chain on your saw.
Dec 18, 2013 | Echo CS600P Gas Chainsaw 20 Inch
How can I trouble shoot the kill switch on a echo weed eater. The spark plug is good as it has ben tested on another machine. There is no spark and seems the kill switch should be the next obvious thing...
Check the kill switch terminals with a continuity tester (small multi-meter will work). If the switch is Ok and there is no spark, take off the engine cover and check the "air-gap" between the magnets in the flywheel and the ignition module legs.The closer the better, but you want about a ,008-.010"gap there...about the width of a standard sized business card. Metal feeler gauges "stick" of course to the magnet area in the flywheel and throw off clearance sensitivity. Try it with a business card. If not in range, then loosen the coil screws, double the card over, and let the magnets pull the coil legs into the card...retighten screws and check for spark.
Mar 15, 2011 | Echo Garden
It quit running after it a had been running for 10 min.It will not start again
You will have to check for fuel and spark to the engine. By process of evaluation, you may come to the reason for this failure. Engines need 4 things to operate properly;
1. Good compression (engine not worn out or scored)
2. Good strong spark
3. Clean, fresh fuel mixed right and introduced to the engine correctly.
4. Clean air supply
These things may sound elementary and they are but these machines are very temperamental and if one of the 4 above things is off....performance will suffer or you will get the dreaded no-start condition.
Aug 11, 2010 | ECHO, Inc. PB-251C Handheld Blower
I have an echo chain saw mdl CS-346 trying to get a new cap for the spark plug. told i need give a ssn. # only # i see on engine caling is 5EHXS.0334CA.says engine family. do see number 02083563 under mdl...
The parts folks are probably trying to sell you a new ignition module which has the cap built in. Try alternate sources for a replacement cap--auto parts stores, lawn and garden service centers, motorcycle shops, even wrecking/junk yards. Good luck!
Jul 15, 2010 | Echo Garden
What is the correct ratio for fuel mix for a ECHO weed trimmer..SRM-210
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Sep 04, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
I have an Echo 300E leaf blower and can't find the gas oil mixture.
Here it is straight from ECHO:
Link is http://www.echo-usa.com/faqs.asp
Apr 19, 2009 | Garden
Garden Logo
35 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
