Question about Xerox DocuColor 12 Color Copier
Docucolor 2045 print White areas
Hi, When I send a print job with a solid color for the background of my picture, the color of the solid area doesn't look completely filled. It has a fainted white color through the whole paper. Picture looks faded. Do you know the cause? Thank you! Keith
  • howsimple Jan 22, 2009
    Thank you.
  • howsimple Feb 13, 2009
    Hi, We just had a short circuit and my docucolor 2045 finisher switched went to off. I switched it back on but now my docucolor 2045 copier is not picking up the finisher. I see eights all across the LCD and the button with a circular image is blinking. Am I suppose to punch in some code? Thanks! Keith
  • 62 Answers
A number of reasons can cause this. have you tried each colour individually? after this swap drums and see if fault moves with the drum. otherwise its probably developer
Posted on Jan 21, 2009
Do you offer service repair on a Xerox 2045 in Woodbridge, VA area? We need Corotrons.
los antiguos corotrones eran hilos de oro....
pq no pruebas con un hilo fino de cobre....
Oct 01, 2009 | Xerox DocuColor 12 Color Copier
Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Jul 19, 2009 | Xerox Office Equipment & Supplies
Offset catch tray failure docucolor 2045
there must be a fault with the tray or wiring. There is nothing else that can cause this fault
Feb 14, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print color & B/W
the only thing apart from software corruption is that you could try printing a configuration sheet. If this prints then black printing is working. If it won't then print a test page then you need composite patch 1-7QU5B.ps from the xerox "drivers and downloads" site. If none of this works it is a software reload.
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
White lines Xerox docucolor 12
do an emergency stop on the machine as the paper is just coming into the main path, and you will catch the inage on the IBT. with a bit of luck on the drum as well. Is it not in 1 colour the white lines? Also are they thick or pencil like lines and from lead edge to trail edge?
Jan 01, 2009 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
Poor registration on Xante CL30 HSE
Make sure the drums are properly seated in their cradels, and if posible, avoid designing with white small text in heavy solid areas that are made up of process colours. For reverse type in a black background, use spot color black rather than rich black. Other than than printing on a not as heavy card, that is about all you can do.
Aug 19, 2007 | Xante CL30 HSE Laser Printer
Xerox DocuColor 12 Color Copier Logo
143 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
