Question about Canon PowerShot S1 IS Digital Camera
My Canon sd 1000 won't power on. Battery is OK.
My Canon sd 1000 won't power on. I've checked the battery contacts and insured the battery is OK. It works well in another Canon SD camera. The camera had been working flawlessly.
  • Anonymous Feb 23, 2009
    I just purchased an "as is" Canon sd800 that does not power up I am open to any suggestion on how to repair it. Thanks for any ideas.
  • Anonymous Apr 30, 2009
    Camera won't come on..at..all..I have tried new digital camera batteries...
Check to make sure the batteries you are using have enough strength and volt power, if not it wont work. If they are really cheap, and last only a weak in the remote, they wont power up a camera.
Posted on Mar 16, 2009
Hi, i have a canon 500d trying to fix, thanks, when i put battery in even with power off, or power on, the blue lamp right of LCD stays on (does not blink), and no power on to the camera other than th
Check the HDMI, mini-USB, and SD card connectors for damage. The DC/DC board is part of the front board and it comes with the battery compartment. Check front and back of board for liquid damage and impact. Check SD card slot for damage to the contacts.
Nov 28, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon 1000 d wont turn on
Did you try to recharge the battery? Check if the battery contacts are still clean and shiny? Is the lens still connected as it should be?
These things I should check as a first reaction.
Is the battery still ok, after you charged it? batteries, sometimes just stop working. There is not such thing as a lifetime for a battery that is at least xx months or years. Some batteries die within one year, some survive 10 years. When the camera does not start, place the battery on the list as number one of the suspects.
Dec 30, 2013 | Canon EOS Rebel XS / EOS 1000D Digital...
Battery won't hold it's charge when fitted to the bike even though it charges when bike is running?
You have a drain of power somewhere. Check all the earths that you can reach. Do you have a dodgy alarm that may have water in the connections, or a damp ignition switch. Use some WD40 to obtain better contacts.
Nov 13, 2012 | 2002 Honda XL 1000 V Varadero
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
What's your problem?canon powershot a550 does not power on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 29, 2011 | Canon PowerShot A550 Digital Camera
I have a Canon PowerShot SD600 Digital Camera. The battery has a full charge but the camera will not power up. I press on and nothing happens. What do you recomend?Best RegardsNeil
Oct 02, 2011 | Canon PowerShot SD600 Digital Camera
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
Cannon Speedlite 270EX doesn't turn on and I put new batteries in
Try cleaning out the contacts where the batteries touch. Make sure the battery door is completely flush with the body and see if you've inserted everything correctly. The type of battery you use also effects the flash recycle time and how it operates too. Have you tried using different types of batteries? Try using NI-MH instead of Alkaline and see if the speedlite will power. There's a test button on the flash and also an off-on switch you can try toggling around. The flash itself is very simple so if it still won't power on after all of that, you should contact customer support.
  • http://www.usa.canon.com/cusa/consumer/products/cameras/speedlite_flash_lineup/speedlite_270ex#ServiceAndSupport
May 17, 2011 | Canon Cameras
Every time I switch on my Canon SD 1100 IS is asks me to set date and time. I set date and time and then it lets me take pictures. Next time I switch it on again it asks to set date and time. How could I...
The camera's clock battery has worn out. Unfortunately, on most Canon SD series, this battery is not user serviceable. Recommend contacting Canon to see if they'll replace it, hopefully at a reasonable cost. 1-800-OK-CANON
Dec 30, 2010 | Canon PowerShot SD1000 Digital Camera
I have a Canon PowerShot SD 1000 camera. One day I used the camera to take photos. No problems. that evening I tried to turn on the camera to show the photos to friends and the camera will not power up. I...
May 21, 2010 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
