Hi, have a pioneer sa 1290 amplifier. the volume is very low at full volume and will play through any function you put it on such as,cd,tuner aux, and so on
TRocky
  • 4 Answers
SOURCE: i have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
Posted on Sep 23, 2007
Eagleeyes
  • 199 Answers
SOURCE: E-99 and other times time TOC ERROR shows up.
hi TOC error sounds like its the laser is faulty. you could try a cd cleaning disc. this may cure the problem..
Regards
Mark
www.blueice-electronics.co.uk
Posted on Feb 25, 2008
marsrover
  • 682 Answers
SOURCE: hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Posted on Mar 11, 2008
tech48
  • 624 Answers
SOURCE: Pioneer sx-205 gives a overload
Does it play normal on any sources, or do you only have the tuner and CD for available sources?
There are many different things that can cause this type of problem.
It could be bad solder connections on in the amplifier circuit or power supply, it could be a bad speaker or a bad output channel inside the receiver if this happens only when it gets turned up loud.
The overload warning happens when the amplifier circuit has excessive current or DC voltage on the outputs. Unfortunately the only way to determain if it is the speakers is to change them with other known good speakers and see if it still happens. But before buying any speakers you need to have the receiver ruled out as the source of the problem.
It can also go into overload if you have the wrong type of speakers connected, or too many speakers connected. Each speaker jack should only have one speaker connected toit. If you are using for example, 4 speakers connected to the "A" speaker jacks meant for just 2 speakers, it will create a load to the amplifier that the amplifier is not rated for.
Look on the back of the receiver and it will have listed the proper impeadance for your receiver. Most will say:
8 ohms or more "A" or "B" speakers
16 ohms "A" and "B" speakers
That means you must use 8 ohm or higher ohm rated speakers if you are using only speakers"A" or only speakers "B", but can not use 8 ohm speakers if you are using speakers "A" and "B" at the same time. Then they must be 16 ohm speakers.
Two 8 ohm speakers in one speaker jack is a 4 ohm load, that is why you can not use more than 1 speaker per speaker jack.
I hope you found this information useful, and if I can be more help just let me know.
Dave
Posted on Jun 28, 2008
SOURCE: Hi, I have a Panasonic
Hi, I have the Panasonic SA-EN9, and if you plug your mp3 player (I have and ipod) into the auxiliary socket you should be able to play it by pressing the AUX button on the remote provided.
Hope It Helps :)
Posted on Aug 25, 2008
Turntable hookup to AUX or CD (no Phono input) only producing very weak sound, even at full volume
You are doing nothing wrong at all. It's just that as you say it has no phono input. Which means the sockets you have will NOT amplify the signal. So you need to buy a magnetic cartridge pre-amp and once connected to the aux the weak signal will be at the normal level.
Jul 11, 2017 | Pioneer VSX-818V-K Receiver
How can I conrol the volume of bose sa 3 amp from the aux input ?
That would depend on the preamp. Name it. A true preamp outputs a variable signal.
It's not clear from the manual what the state of the volume output is without the VCA. Most amps default to full ON and the preamp attentuates the signal with a volume control. Try it with a signal that fades in slowly so you can intervene if it gets too loud. If it's full ON a preamp will control its volume.
May 28, 2010 | Bose Lifestyle SA-3 2-Channel Amplifier
How do i connect a pioneer tx-940 to a pioneer
You need two RCA-to-RCA cables (or one double-cable). Connect the L(eft) Output on the tuner to the L(eft) Tuner or Aux(iliary) input on the SA-1040. Connect the R(ight) tuner Output to the correcponding amplifier input.
Oct 07, 2009 | Audio Players & Recorders
No aux sound
Try going through the menus and finding a place where you can adjust the aux level(volume) on my sony it has to be all the way up to match the output of the radio and cd functions-also my mp3 volume has to be up bout 1/4 to even hear it but when i turn it up it really goes then-i dont know if that helps but good luck
May 21, 2009 | Pioneer DEH-P6300 CD Player
How do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Dec 27, 2008 | Pioneer DEH-P7600MP CD Player
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Aug 30, 2008 | Audio Players & Recorders
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
Sep 22, 2007 | Car Audio & Video
Very Low sound
Make sure none of the tape monitor switches are on as this is a typical symptom when one or more of the tape monitor switches are active.
Sep 27, 2006 | Pioneer IS-22CD CD Shelf System
 Grubhead
Grubhead
