Question about Dryers
My new Dayton split phase ceiling fan is rotating the wrong direction. I am really tired of crawling in my attic again but the wiring diagram is on the motor! It needs to go CCW as you look at the cei
Dayton Model 6K030K Belt Drive Fan motor
  • 25 Answers
SOURCE: New Hampton Bay Ceiling fan - runs only in clockwise direction
By using the "switch" to change direction I assume you mean the small slide switch on the side of the fan housing. What you have done is correct and would not affect this switch. The switch is probably bad and you need to return the fan. Suggestion: if the switch is on the housing of the light kit and the light kit connects to the fan with a plug, you are in luck. Go get another fan, swap the light kits and return the fan. Saves you a lot of work. Good luck!
Posted on Jan 18, 2009
dragonsthatk
  • 547 Answers
SOURCE: Need to replace dryer belt.
screw on bracket of motor for tentsion release
Posted on Feb 12, 2009
SOURCE: TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Posted on Feb 17, 2009
SOURCE: Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Posted on Apr 30, 2009
Healeyman
  • 1198 Answers
SOURCE: Asko superior 7004 heats, but drum will not rotate.
Sounds like the belt is broken. See if there is a trouble door in the back so you can inspect the belt. If it is broken, get a new one from the dealer, and ask for instructions for replacement. If you can only get the belt, google your unit for more help.
Posted on May 07, 2009
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
I have a 2hp dayton single phase 240 volt motor that wont start without spinning the motor by hand.
One of the two wires from the capacitor is wrongly connected.
• Check again.
Capacitor should not be in parallel or directly connected to line.
• One terminal only.
Check rotation afterwards.
Jul 31, 2012 | Air Tools & Compressors
I installed a Dayton 4m205j condenser fan motor. It comes on but turns the wrong way. I switched the wires and it still turns the wrong way.
From what I can find on the internet, there should be a plug very close to the motor body that can be reversed to reverse the rotation of the motor. It should be a small rubber plug on the wires leading into the motor.
Also, check inside the wiring compartment for a sketch or notes.
Gary
Aug 15, 2011 | Dayton Permanent Split Capacitor Motor Fan
How to rewire dayton 2m034 to change rotation from CW to CCW.
Check and see if there is a plug with 2 wires coming out of the motor, connected through the plug to two other wires. Reversing the orientation of the plug should change the rotation.
--W/D--
Jan 24, 2011 | Dayton Permanent Split Capacitor Motor Fan
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
Dayton Attic fan running backwards
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Dryers Logo
53 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
