Carrier Furnace Model 58STA/STX not firing
I have just bought a house which has three 58STA/STX furnaces. They are brand new. Two of them are working, but one of them refuses to light. The red neon light is on continuosly. The unit blows cold air.
Please help
  • 1 more comment
  • ravi4259 Jan 21, 2009
    Gas valve is set to "ON". Also I have turned the gas valve going to the unit "ON".
    I tried purging, but the furnace still does not fire. The main fan blows cold air. The small fan does not start. Is this fan suppose to start?
  • RajaShree Jan 31, 2009
    I have the same problem. Last night when we went to the bed heating was working. But when I wake up it was stoped. But when I turn Fan 'ON' , Fan is working but heating is not. Any idea?
  • 700 Answers
Have you checked the gas valve on the unit.. is it set to on? also check the gas valve going to the unit on?
Posted on Jan 21, 2009
  • Todd Born
    Todd Born Jan 21, 2009
    you may need toi purge the line going to the gas vale inside of the furnace so that you get solid gas to it.
  • Todd Born
    yes the combustion blower should be running before the gas valve will open. I've seen where there's debris stuck inside and the blower wheet will not come on. if you can try to remove the fan and see wat may be blocking the blower.
Carrier 58STA/STX furnace false starts even when off or temperature set lower than current.
Is it possible the drain is plugged? The newer furnaces have a moisture drain and will shut down if they are blocked., shutting them down and restarting will reset fault, but will come right back if not fixed.
Dec 24, 2014 | Carrier Heating & Cooling
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Carrier 58STA furnace code 33, no ignition blower stays on. I have a Carrier 58STA furnace. It's getting a code 33 and never trying to ignite. The blower constantly stays on. It is pushing good air...
33 is a limit switch open take your furnace doors off and there should be a wiring diagram. on this furnace the blower will run if this is open. check rool out swict and linits. it sounds like you have a problem with over heating. how does the fire look ? is the vent blocked ? things like thathttp://www.scribd.com/doc/20861415/Carrier-58pav-Service-Maint i think page 9 has falt codes
Feb 11, 2011 | Heating & Cooling
We had a new Carrier Weathermaker Infinity Gas Furnace installed in our home on 9-21-99.The Carrier people said the furnace was in good condition this past October.But prior to that as of April 2010 the...
Your Carrier guys more than likely are Carrier dealers. I would get a second opinion. Most qualified HVAC techs can work on any and all brands. It doesn't need to be a Carrier dealer to work on a Carrier. AND, if they replaced the control board and didn't test the heat, that's a fault on their part. Anytime we change a board or even a thermostat, we check ALL modes and functions. SECOND OPINION!!!
Mar 10, 2017 | Heating & Cooling
My carrier 58sta furncace is blowing cold air constantly
Code 33 is "limit is open or flame switch is open"
FIRST make sure the filter is clean. Turn off unit then turn back on.
if it works but then later gives you a 33 code then you might have a dirty a/c coil (if you have a/c) that will cause the limit to open. 1st try that
Mar 21, 2010 | Carrier Heating & Cooling
I have a carrier furnace, humidifier valve popped fuse
hook up the new transformer to the white (common) from the blower motor, and the lead from the blower motor hooked up to the heat term on the board. (just cut the wires and wire nut all three together)
Nov 18, 2009 | Honeywell HE360A1027 Whole House...
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
Carrier Furnace is not blowing Heat
heres the manual for the unit, look at pages 46-47 and theres a trouble shooting ladder schematic that asks what the systums are then gives the solutions for the fix. if you are still having problems you can request to talk to me and I'll be more than happy to help.
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/58st-13si.pdf
Jan 11, 2009 | Heating & Cooling
Heating & Cooling Logo
1,548 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
